Old 05-15-2021, 12:56 PM   #1
JimZ
JimZ's Avatar
Default Do I need a new distributor body?
Can someone tell me what the dimension should be between the opposing contacts inside a good distributor body. Mine are measuring 2.372” and 2.382”. I am surprised at the .010” difference and since my rotor to contact distance varies from .033 to .038 depending on which contact the rotor is lined up with I am wondering if new bodies have a tighter tolerance between contacts. Thanks.
Jim
JimZ is offline   Reply With Quote
Old 05-15-2021, 05:04 PM   #2
Russ/40
Russ/40's Avatar
Default Re: Do I need a new distributor body?
Don't have the spec, but the only NEW cap I have is 2.410/2.413
Used, I have 2.371/2.376 & 2.430/2.432 (Original I believe)
I don't believe it is all that critical. I wouldn't worry about it. May not be a spec.
Russ/40 is offline   Reply With Quote
Old 05-15-2021, 05:20 PM   #3
Patrick L.
Patrick L.'s Avatar
With only a .005" difference rotor/body I think you're good to go.
Old 05-15-2021, 09:07 PM   #4
JimZ
JimZ's Avatar
Thanks y’all! I feel better about it now.
Old 05-15-2021, 09:40 PM   #5
CWPASADENA
CWPASADENA's Avatar
You can file down the conductors a little to even out the rotor gap if you need to.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 05-15-2021, 09:57 PM   #6
700rpm
700rpm's Avatar
A good spark from rotor to contact point will jump about a quarter inch. That’s what I look for.
Ray Horton, Portland, OR
Old 05-16-2021, 08:54 AM   #7
JimZ
JimZ's Avatar
I had no idea. I was under the impression that it had to be like a spark plug gap. Thanks for this information!
Old 05-16-2021, 11:31 AM   #8
Patrick L.
Patrick L.'s Avatar
The distributor bushing will have some wear causing a difference in the distance/clearance. The body isn't going to be or fit perfectly.
Thread Tools
Display Modes
