05-02-2021, 07:28 PM | #1 |
1940 Steering box
When replacing the roller wheel in a 1940 Ford steering box how do you secure the wheel shaft in position to stop it moving and coming out of the roller shaft?
Thanks |
05-03-2021, 01:13 AM | #2 |
Re: 1940 Steering box
Maybe I should re phrase that and ask How do you stop the pin coming out of the cross shaft? I have looked on Van Pelts site and others regarding rebuilding a steering box but have not found anything regarding this matter. Should I try to pin it or weld it or ?
05-03-2021, 02:05 AM | #3 |
I saw a 40 box recently where a washer had been slipped on to the end of the shaft and welded in place. The weld was crap and had broken allowing the shaft to slide out of the wheel and jamb against the steering box housing. OK if you want to just turn in one direction all of the time. Nasty if you are travelling at speed when the weld lets go.
I think the person that welded the washer to the shaft did not get enough heat into the shaft to stick the washer properly to the shaft. Probably a good method if the thin washer is welded to the thick shaft correctly. Last edited by FlatheadEric; 05-03-2021 at 02:18 AM. |
05-03-2021, 07:08 AM | #4 |
Good spot welds (not tack welds) in several positions, usually no need for a washer since the pin is not supposed to turn.
05-03-2021, 09:46 PM | #5 |
Quote. "I saw a 40 box recently where a washer had been slipped on to the end of the shaft and welded in place. The weld was crap and had broken allowing the shaft to slide out of the wheel and jamb against the steering box housing. OK if you want to just turn in one direction all of the time."
Exactly what happened in mine. It has chewed away the stiffener rib inside the box but fortunately hasn't jammed. It didn't have washers on it but the shaft appears to be hardened steel and the weld didn't stick to it. They must have been a press fit originally. I'm thinking of center punching around the holes before the shaft goes in, putting loctite 406? on it and pressing the shaft in. |
05-19-2021, 06:20 PM | #6 |
Is this normal or do you think the repo worm is not manufactured correctly to compensate for the movement. Or is it me? |
05-20-2021, 11:34 AM | #7 |
that sounds normal.
05-20-2021, 06:46 PM | #8 |
05-20-2021, 07:03 PM | #9 |
That is a built in problem with that type of steering.
