Old 05-10-2014, 02:55 PM   #1
1928Fordman
1928Fordman's Avatar
Default Flathead Camshaft Questions
Hey guys I have a couple of questions for you.
1. Will this Camshaft work in my engine?
2. What do I need to use this Distributor on my engine?
The block that I have is a 59AB that has the reliefs in the block around the valves. The cam is a regrind with .385 lift. I believe it was a later 8BA 49-53 cam that was converted to the earlier style. The heads that I have are the new block letter heads from Edelbrock. I have both a 2 bolt and 3 bolt front timing cover. The distributor is a 3 bolt 37-41 Mallory. Thanks
1928Fordman is offline   Reply With Quote
Old 05-10-2014, 04:06 PM   #2
scooder
Default Re: Flathead Camshaft Questions
From what I can see, you'll need a stubby adaptor on the dizzy end of the cam. You have a short nose cam 21A type and the three bolt ignitions used a long nose (earlier upto 1941) cam.
I spec you can get them from the usual vendors.
Any more info on that cam? Have a good Look around the outside rim of the part the timing gear, sometimes info stamped there.
Martinq
scooder is offline   Reply With Quote
Old 05-10-2014, 06:10 PM   #3
Ol' Ron
Ol' Ron's Avatar
O think you'd be better off with a 11A distributor than the mallory. Bubba can convert it to electronoc and the afvance curve would be better for your engine.
Old 05-11-2014, 06:28 AM   #4
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Attachment 177466Attachment 177467Attachment 177468Attachment 177469Attachment 177470
How do you know it has a .385 lift? Just because it has .385 stamped on the front? It's an 8BA 49-50 cam. I didn't think you could grind .385 lift on that cam without grinding the heel down a lot lower that the pic shows. Did tou measure the lift? Walt
