Old 06-23-2011, 06:23 PM   #21
Bruce Adams
Bruce Adams's Avatar
Default Re: USB 5v power from Model A 6v geni/battery
I have a small ACE 12 volt power pack which has a power plug and is rechargeable.
It easily fits under my front seat and powers every accessory you can imagine for days before needing an overnight charge.
They are often on sale for $30.
Bruce Adams is offline   Reply With Quote
Old 08-21-2015, 01:08 PM   #22
jetlagjim
Originally Posted by Kevin in NJ View Post
More than one guy has reported direct connect to the 6V works for them.
I personally would want the voltage to be better regulated and protected against over voltage. Seems to me there would be a market for a 5 volt regulated USB power port for the A that works off of the 6 volts.
I would also think a small 6 to 12 converter and then any of these off the shelf 12v to USB adapters would be a good safe solution too.
Bought this. It's tiny. Now just trying to figure out how to wire and mount it.
http://www.amazon.com/gp/product/B00...ilpage_o02_s00
jetlagjim is offline   Reply With Quote
Old 08-21-2015, 01:43 PM   #23
TinCup
TinCup's Avatar
I have hooked them up directly as well and with older chargers for GPS they have worked but with several newer USB chargers for phones they have actually blown the charger. Not sure what is different about these but something has changed.
TinCup is offline   Reply With Quote
Old 08-21-2015, 11:33 PM   #24
Mike V. Florida
Mike V. Florida's Avatar
Based on the number of posts, welcome!
How about getting a cigarette lighter, placing the unit inside with what ever is necessary to hold it firm and using a cap for the lighter opening.
http://www.dormanproducts.com/itemde...4&SEName=56415
Old 08-22-2015, 12:41 AM   #25
Henry's Lady's Man
Henry's Lady's Man's Avatar
Here's a DC industry grade 6v to 12v 1A step-up transformer I just purchased for getting 12v. Paralleling 2 of these would deliver 2A. $18 + $8 shipping each.
http://www.ebay.com/sch/i.html?_from...erter&_sacat=0
... prosperity is not the product of charity but of industry - HENRY FORD
Henry's Lady's Man is offline   Reply With Quote
Old 08-22-2015, 12:49 AM   #26
Mike V. Florida
Then you would use an adapter to bring it back to 5v for the GPS?
Old 08-22-2015, 12:58 AM   #27
Henry's Lady's Man
I think YES, for that application. But don't GPS's run on 12v too?
Old 08-22-2015, 01:01 AM   #28
Henry's Lady's Man
I mean, they run on 5v, but the cigar outlet is 12v, and it is converted to 5v, as someone stated earlier. Electronics is not my forte'. Chuck
Old 08-22-2015, 01:54 AM   #29
Mike V. Florida
I only ask because the thread is titled "USB 5v from Model A, 6v geni/battery". Seems that 6v to 12 volt then back down to 5 volt is a little over kill as compared to jetlagjag's unit or even an home made regulator.
That is not to say yours won't work.
Old 08-22-2015, 11:24 PM   #30
MVal
Several years Tom Wesenbury posted a "how to" on wiring in a cigar lighter for use with a gps, cell phone, etc. complete with pictures and wiring details. I tried finding it with the search function but couldn't so maybe someone else with more experience can do so. Am positive of this as I had our club newsletter editor include it in our club newsletter.
MVal is offline   Reply With Quote
Old 08-23-2015, 03:51 AM   #31
Tom Wesenberg
Tom Wesenberg's Avatar
I bought an insulated lighter socket on ebay for a couple dollars, and I simply wired the center terminal to the ground, and the case to any power source close by. The socket can lay loose on the floor or be mounted with tape or a hose clamp to the steering post. I use it for my GPS, and it works fine with no extra electronic devices needed.
I don't own a cell phone, but others report it also works fine for them.
