02-01-2022, 10:07 AM | #1 |
Muffler protection
During the pandemic I try to run my cars 20 minutes a month to dry out the mufflers. Sometimes I forget.
Cai drill a drain hole in the muffler? If so, where? Is there anything I can run thru the engine that will protect the muffler innards? |
02-01-2022, 10:28 AM | #2 |
Re: Muffler protection
Clem, Ford suggested that a 1/8" diameter hole be drilled at the very bottom - rear of the muffler.
02-01-2022, 11:06 AM | #3 |
I do what Kube suggests. Works fine.
02-01-2022, 10:45 PM | #4 |
I did it too. Worked fine.
But what’s this about drying out the muffler once a month? Why would you need to do that? Would seem to me running the engine is what introduces humidity/condensation into the muffler, and then the need to get everything warm enough to burn off the condensation. I would think if engine hadn’t been run, muffler is fine as is. |
02-02-2022, 04:10 PM | #5 |
Clem When I bought my '46 Coupe, the muffler was rusted through in several places. When I replaced it, I drilled a 1/8" hole at each end, on the lowest point of the muffler, just inboard of the rolled flange. I know the holes are doing the job, because I find the sooty water spots right where the muffler was when I start the car and back it out of the garage.
02-02-2022, 04:26 PM | #6 |
