Old 01-09-2021, 09:56 PM   #1
ChadCurrent
Default Y block Oil pump drive shaft
I'm kinda confused here. My uncle and I were trying to get the ol 56 tbird running today and we were having trouble getting the oil pump primed up tothe heads. Long story short the melling is-42 drive shaft appears to be too short. It's 8 inches long. Why would the standard shaft be too short?
I nok w believe I need an is-60a which is 9.1 inchs. ?
I was able to make the pump work using a long apex extension which pushed oil out the oil filter hole.
Also if anyone knows where I can buy a throttle linkage to attach an edelbrock 500cfm carburetor to the bell crank assembly? Mine is a bit too short.
ChadCurrent is offline   Reply With Quote
Old 01-10-2021, 05:59 AM   #2
darrell
Default Re: Y block Oil pump drive shaft
lots of people are having trouble with replacement distributors being to short not the shaft.check yours against the old one.
darrell is offline   Reply With Quote
Old 01-10-2021, 07:35 AM   #3
ChadCurrent
The pump shaft isn't sticking out the hole.
Old 01-10-2021, 08:08 AM   #4
darrell
the standard shafts are all the same.they dont stick out of the hole.
Old 01-10-2021, 10:35 AM   #5
ChadCurrent
Ah I'm an idiot lol. I see now that the distributor looks like it has a socket that sticks out below the gear.
I was trying to get a 1/4 in apex on it to try and pre pump oil through the engine before installing the distributor.
I need to pull the oil pump and install the drive from below 😆
