Old 10-04-2020, 04:40 AM   #1
30aadoodlebug
30aadoodlebug's Avatar
Default 50 ford woodie chassis finally in derusticator!
The title says it all, I finally built the tank to do electrolysis on my 50 woodie chassis. The beauty of this process is there is no metal spread or integrity compromise, all it takes is time. The process is nothing but a chemical reaction created using washing soda and water, and is activated with an anode connected to the positive side of a charger, and the part being cleaned to the negative side.
30aadoodlebug is offline   Reply With Quote
Old 10-04-2020, 05:36 AM   #2
corvette8n
corvette8n's Avatar
Default Re: 50 ford woodie chassis finally in derusticator!
Can’t wait to see the final product.
Old 10-04-2020, 06:14 AM   #3
flathead48
I just did a engine block and was very pleased with how well it worked. Good luck
flathead48 is offline   Reply With Quote
Old 10-04-2020, 07:45 AM   #4
hotcoupe
hotcoupe's Avatar
Looks like a plywood box with a plastic liner, very simple. Please post results, interesting.
Tom
hotcoupe is offline   Reply With Quote
Old 10-04-2020, 08:56 AM   #5
tubman
tubman's Avatar
The main knock on electrolysis derusting is that it works "line of sight" only. (You have to have direct access between the cathode and the piece being derusted.) I have used this method myself, and found it effective (though a little messy) when working with individual parts where you can surround the part completely.
I am wondering what you guys have done about this (especially with an engine block).
Old 10-04-2020, 03:28 PM   #6
30aadoodlebug
Its all about suspension in the solution, and the amount of anodes you have to one panode (part being cleaned). I have four old truck springs out of my old f450 as the anodes.
Old 10-04-2020, 03:29 PM   #7
30aadoodlebug
48, Ive done several engines this way, and its the only way to go!
Old 10-05-2020, 01:56 AM   #8
Fortunateson
I have used the method in the past and I prefer it to anything. I still have to get a couple of those mesh grids that are used to reinforce concrete for driveways etc. Going to make up a basket to put in my tank. All four sides and a bottom should do the trick!
Fortunateson is offline   Reply With Quote
