07-21-2015, 01:48 PM | #1 |
oil CHANGE
I would appreciate some input re engine oil.
We have a recently rebuilt "touring" engine. The engine builder suggested Valvolene VR-1 Race oil. Which we have used the ffirst 1K. But....that stuff is $11 quart. What about the rest if you.... Cannot believe Many of you are filling up with the VR-1. What do you use? Do you add lead.... Or anything else? And with normal driving .... How often change your oil? Thanks for the feedback. Gil. NoCal Last edited by Gil Sissons; 07-22-2015 at 11:05 AM. Reason: modify heading |
07-21-2015, 02:09 PM | #2 |
Re: oil
Contact your builder he can tell you what he uses after break in :-)
07-21-2015, 02:19 PM | #3 |
Re: oil
any multigrade oil you like, I use 20-50 valvolene, make sure on the badge on the front of the container does not say (for gasoline engines) it does not have zink in it, it is for modern engines with roller tappet cams and lifters and catalytic converters
07-21-2015, 04:19 PM | #4 |
Re: oil
Rotella "diesel" oil, 15-40 is what I use. It's about 15 a gallon and is a good oil for flat tappet type engines. Its what my builder recommends for race engines with flat tappet cams or roller cams and it gets the job done well in the model a. We could get into a whole nother discussion about whether the model a needs the zinc or not due to the camshaft material vs. modern camshaft materials but we don't have to. I prefer to have the zinc as I know it helps with other engines and it sure can't hurt. JMO
07-21-2015, 04:58 PM | #5 |
Re: oil
Sure beats the $12.50/liter I paid for Mobil 1 while on vacation in Canada a couple of weeks ago for my modern.
07-21-2015, 05:26 PM | #6 |
Re: oil
07-21-2015, 07:18 PM | #7 |
Re: oil
Gil, if your engine has a warranty from the builder you might want to stay with his recommendation. I use synethic 10w-30 with changes at 1,000 miles. I buy my "oil" at Walmart in 5 gallon jugs. Disclaimer: I know absolutely nothing about oil but have had superb results or "luck" using full synethic in trucks and cars.. And there is no need for a $55.00 oil fill in any A.
07-21-2015, 07:19 PM | #8 | |
Re: oil
07-21-2015, 08:38 PM | #9 |
Re: oil
LOL bdave, no the a's didn't have zink in the oil for them it wasn't used in oil then, but I bet Henry would have called for it if he had access to it, any thing that reduces friction and wear is good for any engine, modern cars running oil with zink in it will go for over 200,000 miles, will your model A do that?
07-21-2015, 09:04 PM | #10 |
Re: oil
Now that would be nice!
07-21-2015, 09:15 PM | #11 |
Re: oil
Any brand name oil will be OK. Stay away from non-detergent. Remember you will change it after 500 miles!
07-21-2015, 09:24 PM | #12 |
Re: oil
I am bad about whining about prices ,., my wife laughs at me ,., but in prospective it cost me about 35 bucks to change oil in my lawn mower /tractor ,. oh and you have to Grease the front end before every use or its a bear to steer ,., I think they put too much weight on the front .,
My Daddy always said son oil is cheaper than bearings ., ,., ., ., ,.,.,
Sometimes I want to say ,,You should have bought a Shay. |
07-21-2015, 11:24 PM | #13 |
Re: oil
I have a new rebuilt and its tight ..so I put in 5-20 for the first 1000.
07-22-2015, 10:47 AM | #14 |
Re: oil
Thanks for the input.
What about oil changes? Yes.... I know in the day.... With the quality of oil Combined with road conditions .... 500 miles was The standard mark. What do you do change wise? |
07-22-2015, 09:30 PM | #15 |
Re: oil CHANGE
Now using synethic so every 1,000 but I love changing oil or doing maintenance on my A so it might be sooner.
07-22-2015, 10:05 PM | #16 |
Re: oil
Walmart gets about $24 for five quarts, or less than $5 per liter for MOBIL ONE. I use it in my Model A as well as my modern cars and trucks. I DO WONDER why someone would suggest synthetic oil for "Break In Oil" though. I used Mineral Oil, (Castrol 5W30) for my rebuilt Model A Engine during break in.
07-23-2015, 03:50 AM | #17 |
Re: oil CHANGE
I change it with the oil I take out of my truck.. ;-)
07-23-2015, 06:45 AM | #18 | |
Re: oil
07-23-2015, 06:52 AM | #19 |
Re: oil
Someone will dispute this, probably, But a better method would be to use a cheap oil for the first 10 hours ( Part of that is high idle) and then dump it.When I was working on airplanes, we would run mineral oil for a short time and drain it in new engines. Then replace with our normal running oil. Newly rebuilt engines need a flush soon after starting.
Terry |
07-23-2015, 04:37 PM | #20 |
Re: oil CHANGE
I' ve only used 10W30 detergent oil in my '30 Ford since I bought it in 2000. Of course the engine was rebuilt and very clean inside. The oil works as advertised.
I don't believe in non-detgergent oil at all. I'm convinced that if Ford had detergent oil available to him, that's what he would have recommended. Rog |
07-23-2015, 10:53 PM | #21 | |
Re: oil
07-23-2015, 11:08 PM | #22 |
Re: oil CHANGE
Well... I went back to the discount auto to buy oil.
Finally got to talk to someone who could deal a little. Since the engine builder had specked the VR-1 Racing oil... Felt 1 more try to get it at reasonable price Was worth a try. Bottom line...they had wanted $11 per quart. And got it for $6 quart. So oil change costs $30. Now that break in is done builder says 1000 miles Between service works fine. Gil. NoCal |
