11-07-2014, 06:20 PM | #1 |
Exhaust Manifold question
We are getting ready to install the rebuilt engine. I have a 31 exhaust Manifold that has been bead blasted and nice & clean. Had the face cleaned up so should be nice match with the block. The intake was bolted up to it at the resurface.
Question: The exhaust manifold looks really nice right now. I realize if I would have thought of it earlier I might have ordered the Eastwood high temp clear sealer for the manifold. I have some "Duplicolor" high temp clear for manifolds that will be here this weekend. Any of you tried this product? Any feedback? Thanks. Gil NoCal |
11-07-2014, 07:12 PM | #2 |
Re: Exhaust Manifold question
From what I've read, most folks don't have much luck keeping any type of high heat paint looking nice for very long.
Eastwood has a manifold coating called Calyx. Most folks who use it say it looks great and lasts long.
1929 Coupe 1930 Coupe 1935 Ford 5 window coupe |
11-07-2014, 07:25 PM | #3 | |
11-08-2014, 03:11 AM | #4 |
I used VHT Newcast and it looked nice and held up well for about 5 years. My manifold still looks good, but most of the paint is now gone, so it's time for a refresh.
I'm pulling my engine to investigate the ticking noise, so it will get a repaint in the spring when I can work on it. |
11-08-2014, 08:17 AM | #5 |
I put my manifold back on a couple weeks ago. I didn't go out and buy exhaust manifold paint. I had a can of Duplicolor engine paint on the shelf so I just sprayed that on. It looks great on the intake manifold but burned off completely on the exhaust manifold.
11-08-2014, 11:03 AM | #6 |
11-08-2014, 12:05 PM | #7 |
Eastwood cast iron grey. put it on 3 years ago and have not touched it since.
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
11-09-2014, 07:39 PM | #8 |
Sounds like Eastwood is a very good option. What do you think of using this product after running the engine 10 -12 hrs? Would the overall end product still work? Thanks to all for the input. Gil NoCal
11-09-2014, 08:21 PM | #9 |
I've had great results with Cast Blast from Snyders and I don't see how anything could be better. I just wire brushed rusty exhaust manifolds as clean as I could get them, sprayed it on and it has held up eight going on nine years and still looks good to me. I didn't bake the manifolds in an oven. I spray canned the manifolds and they sit on the shelf for probably a month before I installed them and put them into service. Cast Blast isn't expensive and looks pretty much like new cast iron.
