Old 01-18-2022, 10:36 PM   #1
Clem Clement
Clem Clement's Avatar
Default Failed fuel shutoff valve
Some time back we were working on rust in the gas tank. We wanted to remove the shut off valve but were afraid on shearing it off. If we get back to that task and the very tight shutoff valve crumbles, how hard is it to dig out the remaining threads of the valve?
Clem
Old 01-18-2022, 11:06 PM   #2
koates
Default Re: Failed fuel shutoff valve
Clem, exactly what car and what tank and valve are you talking about ? Is it your model A Ford ? Regards, Kevin.
koates is offline   Reply With Quote
Old 01-18-2022, 11:39 PM   #3
Newc
Newc's Avatar
Hi; I use a rotary file in a varialble speed drill nd cut until I can see threads then pry out the the fitting with an aul or pic. Best results if routed out in two adjacent areas. Newc
Old 01-20-2022, 08:31 PM   #4
Clem Clement
Thanks. With the tank out of the car?
Old 01-21-2022, 03:26 PM   #5
Tim Ayers
Wait, so part of the stem is stuck in the female threads? If so, they make internal thread removers for plumbing for this exact situation. You can get them in various sizes.
