Old 08-10-2020, 07:20 AM   #1
David R.
Default Zenith or Tillotson
Working on a AA. As found it had a Tillotson in pretty good shape. Any pros or cons to running the aftermarket carb on a driver? Working on rebuilding an engine now
David R. is offline   Reply With Quote
Old 08-10-2020, 07:53 AM   #2
McMimmcs
McMimmcs's Avatar
Default Re: Zenith or Tillotson
Do a search. Mountains of threads on this subject! [/B]
Old 08-10-2020, 08:23 AM   #3
leo
leo's Avatar
Mountains of opinions too!
leo is offline   Reply With Quote
Old 08-10-2020, 10:30 AM   #4
WHN
Rebuilt or new Zenith, another problem area solved.
I learned this the hard way!
Enjoy.
Old 08-10-2020, 11:42 AM   #5
Big hammer
If the Tillotson was working good, spend your money on the cooling system, with a tight fresh motor your cooling system will be taxed
get a bigger hammer tap done
Old 08-10-2020, 11:50 AM   #6
Ruth
Enjoy.
I bought a new Zenith... once. It ran so lean my plugs were white. Even after installing Renner's flowed jets it ran too lean.
Finally traced it to the throttle shaft. It was so loose an oversize shaft almost fit with no reaming. It was not even round (the hole, not the shaft). It was sucking so much air in thru the throttle shaft (downstream of the jets) there was no way I could richen it up enough.
Moral of this tail; If you buy a new Zenith, check it closely. New is not better.
Update: I see new Zeniths are "Temporarily out of stock" at all of the vendors. Perhaps I am not the only one that had issues?
Ruth
Old 08-10-2020, 01:55 PM   #7
Patrick L.
Patrick L.'s Avatar
Just installed another Zenith recently. Could never get one to idle like I liked and all had a decal gallop that I couldn't adjust out. Went thru a half dozen over the years.
Car had a Tillotson when we bought it. Acquired a few more over the years. Just installed the Tilly yesterday and glad I did. They run so much better.
I like Marvel, but, only have one. It works very well.
Old 08-10-2020, 02:08 PM   #8
mcgarrett
I have a '31 Slant windshield with the correct side bowl Zenith and it seemed to run OK as far as I was concerned. A friend came across some NOS Tillotsons and gave me one. It had never been installed on a car judging from the lack of marks on the casting where the bolts tighten down. I was surprised at how much better the car seemed to run compared to the old Zenith. Maybe it ran better since it was new, but I noticed the difference in the smoother idle and better throttle response.
Old 08-10-2020, 02:10 PM   #9
abachman3
abachman3's Avatar
The Tillotson is currently used on a lot of Model A motors and seems to be acceptable. Purists will tell you that you need a Zenith. The choice is yours. If it runs well with the Tillotson, go ahead and use it! As mentioned in one of the other answers, there is also a Marvel Schebler carb that is used by a good number of people.
abachman3 is offline   Reply With Quote
Old 08-10-2020, 04:51 PM   #10
David R.
It sounds like the Tillotson will get a good tune up and cleaning while the engine is at the machine shop. Thanks guys. I understand about new not being better. Been down that road. I learned along time ago not to turn in your core before you check out the ‘rebuilt’ parts. Got a rebuilt starter once in worse shape than my old one.
I also build flintlock rifles and had to make bushings for one new lock because it had so much slop in tumbler bearings and ended up making new springs to get it functioning properly.
Old 08-10-2020, 07:34 PM   #11
Bruce of MN
Bruce of MN's Avatar
“Zenith for show, Tillotson for go!”
Old 08-10-2020, 08:07 PM   #12
David R.
I want a go truck for sure and don’t plan on winning any shows with it. I will keep the tilli at least for now.
Old 08-11-2020, 12:08 AM   #13
updraught
updraught's Avatar
It will warp and suck air regularly. Zeniths in this part of the world always look like they have been a sacrificial anode at a plumbers convention. I haven't found one worth resuscitating.
https://www.fordbarn.com/forum/showthread.php?t=135403
updraught is offline   Reply With Quote
Old 08-11-2020, 05:18 AM   #14
Patrick L.
Patrick L.'s Avatar
Yep, I forgot about that
Old 08-11-2020, 05:21 AM   #15
Patrick L.
Patrick L.'s Avatar
Tilly's are good carburetors. They are know for warping the body, but, thats not hard to fix. Be careful when taking them apart, especially the drain plug and nozzle. The threads are fragile.
Old 08-11-2020, 05:26 AM   #16
DBSHELTON
I run both and can't tell the difference when both carbs are set up and adjusted correctly. But I always check all surfaces for flatness.
DBSHELTON is offline   Reply With Quote
Old 08-11-2020, 07:45 AM   #17
leo
leo's Avatar
Hey, no posts for Marvel carburetors? Every bit as good as a Zenith, Tillotson or maybe even better......
Old 08-11-2020, 08:07 AM   #18
DBSHELTON
I hear they are better.
Old 08-11-2020, 11:43 AM   #19
Purdy Swoft
Purdy Swoft's Avatar
I prefer the Marvel carburetor more than the Tillotson . I always prefer the cast iron Zenith carburetor over any pot metal carburetor .
Old 08-11-2020, 12:16 PM   #20
Patrick L.
Patrick L.'s Avatar
It was mentioned.
