Old 04-12-2021, 04:15 PM   #1
56sedandelivery
56sedandelivery's Avatar
Default dash questions
Couple questions on the dash. On the bracket that the dash rest on there was some kind of sealer or something. Do you know what was use and if it is needed? Sound deadener maybe? I have no found anything in the trim manual on this.
On the window frame there are clips that hold the inside molding on. I am missing one of these and have not found any as yet. Can something else be used in its place? Enclosed photos
56sedandelivery is offline   Reply With Quote
Old 04-12-2021, 06:54 PM   #2
Daves55Sedan
Daves55Sedan's Avatar
Default Re: dash questions
For the L-shaped brackets that the dash sits on, I just cut out a square piece of roofing felt and punched a hole in it for the bolt to go thru. The factory may have used a bit of their seam-sealer between the bracket and dash as an anti-squeak.
The clips are used for holding your windlace in place prior to installing the interior garnish mouldings. To my knowledge, these are not being reproduced by any of the popular repro parts suppliers. Some people are abandoning those clips and using small, short screws with washers to hold the windlace in place. But you gotta drill holes for that and its best to punch out the mating holes in the flat portion of the windlace.
Daves55Sedan is offline   Reply With Quote
Old 04-14-2021, 11:56 AM   #3
56sedandelivery
What is windlace? I do not recall anything there when I removed the garnish. I may have to try and make one of those clips.
Thanks for the felt idea.
Old 04-14-2021, 12:25 PM   #4
Dobie Gillis
Dobie Gillis's Avatar
Windlace is a piece of fabric folded over a soft foam core giving it its round shape and gets placed around the opening of doors and gives the upholstery a finished look.
http://www.route66hotrodhigh.com/Windlace.html
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 04-14-2021, 01:08 PM   #5
56sedandelivery
Thanks Dobie
May not have had that since it was a sedan delivery and had no interior upholstery to speak of. At least I don't remember any but then again it has been decade since I took it apart.
Old 04-14-2021, 06:54 PM   #6
Daves55Sedan
All sedan and wagon models had windlace, even the Mainlines and Couriers.
Old 04-15-2021, 07:08 AM   #7
Ford blue blood
Ford blue blood's Avatar
A similar clip is available from the T-Bird suppliers. I used them in my Ranchero. They fit the holes in the sheet metal, are longer but the same height as the originals.
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 04-15-2021, 10:56 AM   #8
56sedandelivery
Do you know where you got those? I could not find them at Larrys TBird.
Old 04-15-2021, 06:18 PM   #9
rotorwrench
rotorwrench's Avatar
Ford used a sealer that is very much like the old Tite-Seal compound (the thicker one). The stuff is called Neil-Seal now. I use the medium weight type P/N N25-66.
Old 04-18-2021, 07:07 AM   #10
Ford blue blood
Bird Nest Inc., part #02614, $3.55 ea.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
Old 04-19-2021, 01:04 PM   #11
56sedandelivery
Will try one but looks taller then what is in there now.
Old 04-24-2021, 05:55 PM   #12
Gene F
Gene F's Avatar
the councourse parts calaog has photos of a whole array of clips.
Gene F is offline   Reply With Quote
