03-17-2021, 11:54 AM | #1 |
Is there any concern using modern day oil say 10W30 in a 1951 ford 6 cylinder engine
Is there any concern with using Modern day oil such as 10W 30 in a 1951 Ford Custom 6 cylinder engine due to solid valves and lifters?
Thanks! |
03-17-2021, 12:21 PM | #2 |
Re: Is there any concern using modern day oil say 10W30 in a 1951 ford 6 cylinder eng
Nope. Just stay away from non-detergent no matter what "they" tell you.
03-17-2021, 12:35 PM | #3 |
The only concern will be slug.
Even if the oil was changed regularly, with non detergent oil, slug will be present. Detergent oil, will loosen the slug and potentially clog the oil pick up screen. It doesn't do the bearings any good if, it does get threw the screen, either. That said, it would be hard to believe a car that old, would not have had detergent oil at some of it's oil changes, unless the previous owner attested to only using non detergent oil. The only way to know if slug is present, is to pull the tappet cover or pan. Maybe pull the oil fill tube and run your finger around, below it. I was a mechanic, in those transition days (62-70), from non detergent, to detergent oils. In my first years, I saw, and cleaned, a LOT of slug.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
03-17-2021, 02:38 PM | #4 |
[QUOTE=frnkeore;1997194]The only concern will be slug.[QUOTE]
Yes, 'sludge' is a concern....
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 03-17-2021 at 02:44 PM. |
03-17-2021, 03:06 PM | #5 | |
[QUOTE=petehoovie;1997235][QUOTE=frnkeore;1997194]The only concern will be slug.
I think there was a family of "slugs" in there.
03-17-2021, 04:57 PM | #6 |
BTW, does your engine have an oil filter? If so, how does it look? |
03-17-2021, 06:28 PM | #7 |
Thanks for the responses, yes it does have an oil filter. I have not drained oil yet. I just got it running. I need to change the oil since who knows how long it has been in the engine. I have put some marvel mystery oil in it to get some extra lubrication into the engine along with the unknown oil. I will be checking on the residual in the oil filter housing.
Thanks Again! |
03-17-2021, 07:27 PM | #8 |
I don't believe this business one bit about modern oil loosening engine deposits. Probably not a bad idea to change the oil relatively often.
03-17-2021, 08:09 PM | #9 |
don't use synthetics, it will just leak out profusely. 15w40 rotella diesel oil is a good choice or I use 20x50 kendall both of these are good oils that will not run out of the engine as fast as you put it in. I would also use mmo in the gas and a little in the crankcase to help with sticking valves
03-17-2021, 08:33 PM | #10 |
I will take an unpopular position here and say that an additive package designed for use in diesel trucks may not be the best choice for use in a spark ignition automotive engine. I really have to believe that the chemists at the major oil companies have a pretty good idea of what they are doing.
Also, I have used 15-50 Mobil-1 synthetic in my '51 ford for the last couple of years (I had two cases left over from my racing days). I have had no problems with leaks. It is a fairly fresh engine though. Perhaps an engine with a bunch of miles may be more susceptible to leaks. |
03-18-2021, 02:35 AM | #11 | |
I was there, I saw it and had to cleaned that "sludge". In modern times, I doubt that there are many that ever saw real sludge. The deposits inside a engine today, even if the oil was rarely changed, are nothing like the non detergent sludge. Sludge could be to 1/4 to 3/8 thick, it was as black as coal and could have the consistency of thick pudding. Take a engine down, that had a blown head gasket and water in the oil, that got whipped around and mixed with the sludge and you'll wish, you never wanted to be a mechanic. What I stated, in my first post, is true. People that changed their oil, often, didn't have as much but, about 1/2 or so, didn't change the as often as they should.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline Last edited by frnkeore; 03-18-2021 at 02:51 AM. |
03-18-2021, 07:42 AM | #12 |
I use 20-50 in mine to slow down the smoke out the tail pipe, my motor is tired and need a rebuild someday.
03-18-2021, 09:48 AM | #13 |
I use 20-50 in mine from the local Family Dollar store .
1952 Ford F1 1965 Ford Falcon Sprint 2007 Ford Mustang GT |
03-18-2021, 12:52 PM | #14 | |
03-18-2021, 09:39 PM | #15 |
Just to be clear, when I talk about flatheads and oil, I am positing an engine in good shape, not one that is that is all worn out and on it's last legs. An engine that is so full of sludge that detergent oil has any chance of breaking it loose needs an immediate rebuild anyway.
It's not 1959 any more. |
03-19-2021, 12:48 PM | #16 |
I was around when synthetic oil was starting to be used in the early 80s.Our shop used Amsoil and it did tend to leak.
They quickly found out that it needed a change to keep seals soft. They solved that problem and since then synthetic oil does not leak anymore than regular oil John
Welcome each day |
03-19-2021, 02:20 PM | #17 |
If the engine burns oil, it will consume less running synthetic. Don't ask me why, just my experience with previous motors.
Sometimes, ingenuity gets in the way of sense and sanity. |
03-19-2021, 02:57 PM | #18 |
Electric motors?
Alan |
03-19-2021, 03:07 PM | #19 |
Haha, "engines". I do enjoy your humor Alan, i like technicalities. Its good someone holds me to mine own ideals.
03-19-2021, 03:33 PM | #20 |
opinions, are like a hole and elbows, every one has one or two so you choose.
