03-16-2020, 10:00 AM | #1 |
clutch plate
i have a pin on clutch plate that is stuck down and the clutch finger has a lot of play can i take out the clutch housing bolts to the brake drum so see the damage i do not have the time to pull the engine out and the rear end right now
03-16-2020, 01:50 PM | #2 |
Re: clutch plate
Removing the hogs head can be a bear. Some depends on whether it has a starter or not. The top will come off but other things may need to be removed or moved out of the way to get it off & back on again. I don't know if it will allow much disassembly though. This is one persons procedure. There are likely others too.
http://www.mtfca.com/discus/messages...tml?1348584247 |
03-16-2020, 09:29 PM | #3 |
Re: clutch plate
03-18-2020, 03:28 PM | #4 |
Re: clutch plate
My motto is : if you don't have time to do it right, when will you find time to do it over?
03-20-2020, 05:39 PM | #5 |
Re: clutch plate
