08-11-2017, 09:29 AM | #1 |
33-34 rear window help
I'm replacing the wood and all the window channels but I have no glass. Does anyone have the dimensions of the glass. I have the curve on top from the old wood, but need the width and height at the center. Thanks Chuck.
08-11-2017, 09:36 AM | #2 |
Re: 33-34 rear window help
9 13/16" at center and 31 1/8" W from original 34 glass. A friend tried to use the dimensions on a 33 and it did not fit! Suggest you cut some plywood and try before cutting glass.
08-12-2017, 05:57 AM | #3 | |
Plywood is my choice for patterns, thank you very much Chuck. |
