Old 02-08-2021, 12:24 PM   #1
54sunliner
Default 1954 ford car coil wire
i would like to find out if a 1954 ford sunliner v8 originally had a brown color coil spark plug ignition wire like 1955-1957 ford's have?
54sunliner is offline   Reply With Quote
Old 03-07-2021, 10:15 AM   #2
BillCook
Send a message via Yahoo to BillCook
Default Re: 1954 ford car coil wire
Could have been made when the change over came ,but if it’s hot when the ign is on use it !
BillCook is offline   Reply With Quote
Old 03-07-2021, 11:35 PM   #3
Lamar Wadsworth
Lamar Wadsworth's Avatar
All '54 Fords, regardless of engine option or body style, used the same ignition switch and same coil. Follow the wire to see if it goes to the IGN terminal on your switch. If it does, use it.
Lamar Wadsworth is offline   Reply With Quote
Old 03-08-2021, 01:48 AM   #4
dmsfrr
dmsfrr's Avatar
54sunliner may be asking about the hi voltage wire from the center terminal of the ignition coil to the center of the distributor cap.
dmsfrr is online now   Reply With Quote
Old 03-08-2021, 11:39 AM   #5
scicala
scicala's Avatar
I'm pretty sure he is. I never knew they ever used a brown high voltage coil wire in any year.
Sal
scicala is offline   Reply With Quote
Old 03-08-2021, 11:41 AM   #6
scicala
scicala's Avatar
My '55 292 years ago had original plug and coil wires. The coil high voltage cable was black.
Sal
Old 03-08-2021, 07:58 PM   #7
chain drive
the 54 fords had a black wire
chain drive is offline   Reply With Quote
Old 04-08-2021, 08:05 AM   #8
KULTULZ
KULTULZ's Avatar
Post Re: 1954 ford car coil wire
The same COIL WIRE (8EQ 12298) was used (FOMOCO) on the FYB, 1954-1957.
See Attachments Below -
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 04-08-2021, 08:09 PM   #9
paul2748
paul2748's Avatar
But some wires were brown, especially the 55-57. They also had a loose knot in them
48 Ford Conv
56 Tbird
54 Ford Victoria
