Old 04-14-2021, 12:14 AM   #1
coxswain98
Default New fangled water pumps
Anyone have experience with the ceramic seal, bearing based water pumps? Thoughts?
coxswain98 is offline   Reply With Quote
Old 04-14-2021, 11:00 AM   #2
asapguy
asapguy's Avatar
Default Re: New fangled water pumps
Not yet but I have a couple to install on the 40 motor that's in my 35 5W cp. I'm worried about the bolts that are inside the pump area and if they'll come out OK.
asapguy is offline   Reply With Quote
Old 04-14-2021, 01:27 PM   #3
Russ/40
Russ/40's Avatar
They usually do come out fine. If the bolt head is loose fit in the socket, take a metric socket and tap it on the rusted bolt for a tight fit.
Old 04-14-2021, 01:35 PM   #4
KiWinUS
KiWinUS's Avatar
Use 6 point socket. NOT 12pt.
KiWinUS is online now   Reply With Quote
Old 04-14-2021, 02:32 PM   #5
35fordtn
35fordtn's Avatar
The new pumps are excellent. We sell them and I have used and stocked all three brands. they all work perfect. My 40 ran consideralbly cooler with them
Old 04-14-2021, 09:50 PM   #6
51504bat
51504bat's Avatar
And if the bolt head gets buggered up you can try to bang a metric socket on the bolt head. Again 6 point not 12 as stated by KiWinUS.
Old 04-14-2021, 10:46 PM   #7
Talkwrench
Talkwrench's Avatar
Ive been running the Drake pumps for nearly ten years daily , no issues at all.
Use stainless steel bolts and coat them.
Old 04-15-2021, 09:13 AM   #8
51woodie
51woodie's Avatar
I installed a pair of Denis Carpenter pumps on my '46, 59AB, a couple of years ago. They are performing well, no leaks and good temperatures. The impeller design is of the "closed" design, which is more efficient than the original "open" type. The only issues I had, was that one of the pumps had a cracked pulley when I received it, which I didn't notice until I sprayed on the primer paint. DC replaced the faulty pump with no questions. The other thing was, and only because I am very picky, is that the casting surrounding the bolt holes were not spot faced, to make them smooth and parallel to the back face. Ten minutes with an end mill and perfecto.
51woodie is offline   Reply With Quote
