11-01-2017, 11:15 AM | #1 |
ID 1928 AA coupling shaft
I am working on a 28 AA truck with the usual set up of a three speed trans, worm drive rear end. I need the coupling shaft between the trans and rear end tub, that mounts with u-joints. I picked one up thinking it was correct, but turned out to be for a four speed. I just found another one in Denver; I was told is for the three speed application, But all the info I have looked at shows a different type then what I have now. Mine has a heavy cast tub, and the odd bolt pattern for mounting one end. Anyone recognize this unit on their trucks. I also think I am needing a few more parts? View pictures. Any help would be a great help. Thanks...Mike
11-01-2017, 11:23 AM | #2 |
Re: ID 1928 AA coupling shaft
That is used in a Reeve's frame extension kit.
The picture below is a 28-29 coupling shaft. Bob Last edited by Bob C; 11-01-2017 at 05:55 PM. |
11-01-2017, 12:20 PM | #3 | |
Note that the front support (u-joint housing parts) were the same as for the A chassis. The RGJS should cover the different designs (the first had unevenly space bolt holes.
[email protected] - email contact https://aafords.com Ford Model AA Truck Club @ aafords.com |
11-01-2017, 01:36 PM | #4 |
Hello Mike
Thanks for posting about the coupling shaft, I am looking for the correct coupler also, picture below, the one you have is the same is what Steve at Berts sent me a picture of, thanks to Bob C the mystery of where in belongs as been solved. Mike, I just had a thought, would you measure the length of that internal shaft, I am thinking 20 inches, PM me with a reply, Thanks Brian.
Nothing can be made foolproof, ---- fools are ingenious bastards. Last edited by Brian T; 11-01-2017 at 01:44 PM. Reason: Added another paragraph. |
11-02-2017, 09:16 AM | #5 |
Regards...Mike Miller |
