12-21-2015, 01:10 AM | #1 |
Pistons: 3 ring vs 4 ring?
Rebuilding stock merc (3rd generation) for 53 F100. Any advice on best piston choice? Basically stock, just two 97s and headers. Also I see engine stands that support along the sides, usually at exh ports: why not from the back of the block in the more traditional manner? Thanks for advice.
12-21-2015, 02:25 AM | #2 | |
Re: Pistons: 3 ring vs 4 ring?
12-21-2015, 02:24 PM | #3 | |
12-21-2015, 03:55 PM | #4 |
Coopman,
Thanks for posting that. I think it is the first one I've actually seen busted. I think I am going to spring for one of those sidemounts, however, because it looks like it would make engine assembly easier, even though I only mess with 8BA's. Also, I hope to finish my 258" engine next spring. One of the reasons I built the engine is that I got a spectacular deal on a set of new 3 5/16 4-ring pistons. After posting here and a discussion with my engine builder, we decided to leave out the bottom rings because the ring set has the modern 3 piece oil rings. From everything I have found, it is a better choice than using them. Last edited by tubman; 12-23-2015 at 07:07 PM. Reason: Add more info |
12-21-2015, 04:58 PM | #5 | |
I am usually relatively happy------Gary |
12-21-2015, 06:26 PM | #6 |
12-21-2015, 07:26 PM | #7 | |
12-22-2015, 12:33 AM | #8 |
Thanks for the helpful info. Are side mounts for sale or home built?
12-22-2015, 01:48 AM | #9 |
Yes, on the early block as soon as one turns the motor upside down the bellhousing
breaks. I have had to repair two of these that customers broke. |
12-22-2015, 02:02 AM | #10 |
12-22-2015, 01:16 PM | #11 |
12-22-2015, 09:06 PM | #12 | |
http://www.fordbarn.com/forum/showthread.php?t=164965 804-245-1959 Dave Havlir Last edited by V8COOPMAN; 12-23-2015 at 02:45 PM. |
12-23-2015, 02:39 PM | #13 |
Here is another link to Stumpys . . . I've used quite a few of his products - really good guy!
http://www.stumpysfabworks.com/store..._Products.html |
12-23-2015, 03:06 PM | #14 |
I see that this thread has evolved from 3 vs. 4 ring pistons to engine stands. Is there anymore that can be said about the original topic? I like to hear more about the 3 ring versus 4 ring comparison for a stock street flathead. Is the difference really going to be that significant?....
12-23-2015, 03:46 PM | #15 | |
"It is better to run a three ring piston than run a four without the lower oil control ring. The skirt will be slightly less stable. Having said that, I have built many flatheads and left of(f) the lower ring set. Ford had oil control problems and hired some former Olds (engineers) to cure the consumption problem. Their solution was the four ring configuration. That cured the oil consumption problem but caused a new problem of causing the top compression ring to run too dry and overheating. Anyone that has torn down a later flathead and seen the top ring broken and segmented crawling over bits of each other an attest to the dry ring damage. Leave of(f) the bottom ring and live with the minuscule piston rock and oil consumption and not cook the top ring. I learned all this from a couple of old Ford mechanics when I was just starting out in the early 60's. Believe me the pluses far out weigh the minus'(s). Or if you haven't purchased pistons yet, get three (ring) pistons to start with." As others have said, the rings "float" in the piston and have no role in supporting it, so this posters one worry seems unfounded. |
12-23-2015, 04:54 PM | #16 |
[QUOTE=tubman;1210730]This was posted on the H.A.M.B. and influenced my decision :"Ford had oil control problems and hired some former Olds (engineers) to cure the consumption problem. Their solution was the four ring configuration. That cured the oil consumption problem but caused a new problem of causing the top compression ring to run too dry and overheating."
It would seem that MMO in the fuel would resolve this problem....
12-23-2015, 06:20 PM | #17 |
You'd have to put a lot of MMO in the fuel to show any lubricating quality for the rings.
