03-17-2013, 02:52 AM | #1 |
Zenith carb
Does anybody know who made a cast aluminium copy of the zenith? This looks like a zenith, and not a square fuel bowl tilitson.
03-17-2013, 03:50 AM | #2 |
Re: Zenith carb
Tillotson F1B, Simmons, and Wizard all made alloy versions. The F1B is the most common.
Member Purdy Swoft, is to thank for originally posting these pics.
Wanted: Simmons Super Power Head Craig Likon 1931 150B Last edited by ctlikon0712; 03-17-2013 at 06:34 AM. |
03-17-2013, 04:44 AM | #3 |
Re: Zenith carb
Thanks Craig, the one I saw is on the Australian ebay site.
Link - http://www.ebay.com.au/itm/Model-A-F...item2c6d32d2fe |
03-17-2013, 06:33 AM | #4 |
Re: Zenith carb
That is either a Simmons or Wizard, they were both made by Simmons.
The Simmons will have a brass tag riveted (drive rivets) on the right upper housing. I have seen some alloy Simmons carbs with no tag or rivet holes. The Alloy Simmons was made for better MPG and had a much smaller main jet and a smaller different design venturi. All of the Simmons carbs have a high speed passage that cuts in at about 2/3 wide open throttle. I would be hesitant to say that is uses all the same parts and gaskets as a Zenith. I have never owned one, everything that I have relayed to you I learned from Purdy.
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
03-17-2013, 01:55 PM | #5 |
Re: Zenith carb
Thanks Craig, all good info and purdy pics!! I just noticed .
03-17-2013, 02:33 PM | #6 |
Re: Zenith carb
03-17-2013, 06:00 PM | #7 |
Re: Zenith carb
I looked closer, and it looks as if the lower half of the lever has been broken off.
