Old 03-07-2013, 08:42 AM   #1
dave in australia
Default multi plate clutch
I have some multi plate flywheels. On some, the splines for the clutch are part of the flywheel, and on others, the splines are a separate item and bolted to the flywheel. Are the bolt on splines a variation of the original setup, or has someone in the past machined off worn splines and fitted replacement splines?
dave in australia is offline   Reply With Quote
Old 03-07-2013, 08:52 AM   #2
Farrell In Vancouver
Farrell In Vancouver's Avatar
Default Re: multi plate clutch
I have never seen a multi-plate flywheel with bolted in splines. Got any pix?
Farrell In Vancouver is offline   Reply With Quote
Old 03-07-2013, 10:57 AM   #3
Fred
A few pictures would really help.. I have 4-5 & 1 NOS & none bolt on..
Fred is offline   Reply With Quote
Old 03-07-2013, 11:41 AM   #4
Rowdy
I have seen one bolt on style. Unfortunately the area that bolted to the crank shaft was broke out. I think it was likely thinner in that area which contributed to its failure. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 03-07-2013, 04:35 PM   #5
binkbee
I have one, regular [not bolted] that is every bit like it was when new---no wear at all in the splines.Also have the complete clutch ass. on a transmission with housing and pedals & linkages. All came out of a low mileage coupe in the fifties. [email protected]
binkbee is offline   Reply With Quote
