08-03-2017, 12:56 AM | #1 |
34 3 window door glass ,
Trying to assemble the door glass on a 34 ,,3 window ,got a new track but have my dough's whether its correct .Does any one have the measurements of a original track ,the gap ?,were the screw is located ,how close to the front of the glass the track finishes how close of the Cam crank to the end ,Thanks for any help .Ted
Fitting procedure (1) fit the crank mechanism (2) crank it so the arms are face down or up ,?? Slide the glass vertically down the door opening . (3) with the screw removed on the track and one on the crank cog, (4) turn the arms with in 3: of each other fit then in the track , (5) replace the screws . |
08-03-2017, 02:39 AM | #2 |
Re: 34 3 window door glass ,
Arms should be pointing down
08-03-2017, 02:49 PM | #3 |
Thanks Deuce ,any more offers ?
08-03-2017, 03:26 PM | #4 |
Have you seen this thread?
https://www.fordbarn.com/forum/showt...window+channel Many more measurements in the V8 club 34 book. On my 2 dr, window up, crank the arms up, then crank down to spread slides into channel, then get to the stop screw (in channel) through hole. 3 window door is most likely same. Last edited by johnboy34; 08-03-2017 at 03:34 PM. |
08-03-2017, 05:56 PM | #5 |
