Old 06-04-2021, 04:58 PM   #1
Frosty1
Default 1938 Woody Transmission Cover
I'm looking for a sheet metal transmission cover. Are they all the same?
Bradley Floor Pans makes one for "1937 & 1938 cars" I'm wondering if that includes S/Wagons.
Frosty1 is offline   Reply With Quote
Old 06-05-2021, 08:20 AM   #2
Kube
Kube's Avatar
Default Re: 1938 Woody Transmission Cover
Station wagon pan is the same. Be VERY aware that actually obtaining a pan from Bradley has a success rate near zero.
Old 06-05-2021, 08:46 AM   #3
TJ
TJ's Avatar
Run a want ad on this site for the transmission pan. I'll bet you will get a good used one. Unless Brandley has it "currently" in stock you'll probably never see it in your lifetime.
Old 06-05-2021, 08:48 AM   #4
Kube
Kube's Avatar
Good advice indeed.
Old 06-05-2021, 10:55 PM   #5
swoopNZ
MEMBER EMERITUS
37 and 38 are pretty much the same.
39's are wider across the top and have a semi-circular cutout on the upper LH side.
swoopNZ is offline   Reply With Quote
Old 06-05-2021, 11:38 PM   #6
Frosty1
Thanks to all. I've actually been waiting 4 days for Bradley to reply to my query.
However, the "Tin Doctor" has been in touch with a cover.
