Old 06-16-2019, 06:55 AM   #1
Ideucev8
Default 32 Pickup Bed mounting bolts
What did Ford use for the front mounting bolts of the pickup bed? Did they go right through from the deck. I have a new Macks Products bed. Thanks,
Phil.
Ideucev8 is online now   Reply With Quote
Old 06-18-2019, 05:13 PM   #2
Ideucev8
Default Re: 32 Pickup Bed mounting bolts
Can anyone help please
Old 07-06-2019, 07:04 AM   #3
Ideucev8
Someone must know.
Thanks Phil
Old 07-06-2019, 07:52 AM   #4
A bones
A bones's Avatar
Can't imagine why this has gone unnoticed. I'll send a message to our 32 Guru.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 07-06-2019, 08:04 AM   #5
glennpm
glennpm's Avatar
Hi,
I don't have a 32 pickup but just did a search and found a possible answer. If these are mounting bolts, check your frame for matching holes, i.e., the distance between the bed holes and the distance between the frame holes. If they are mounting bolts they would go through the bed and then through the frame too.
https://cgfordparts.com/ufolder/ford...p?number=10328
Old 07-06-2019, 09:03 AM   #6
DavidG
DavidG's Avatar
Glenn,
Pretty sound logic, it seems to me.
I wish that I could provide a definitive answer as I have a '32 pickup nearing final assembly, but I'm very far away from it at present; sorry.
Old 07-06-2019, 09:34 AM   #7
Ideucev8
Thanks, The bed front cross member has holes that line up with the holes in the chassis, but it also has holes in the top of the cross member right under the wood as if the bolt may have come down through the deck.
Old 07-06-2019, 09:51 AM   #8
glennpm
glennpm's Avatar
Since the bolt has a countersunk head, it will come down through from the top. Think about the assembly and final fit and finish. All the bed bolts go from the top side of the bed.
Glenn
Old 07-06-2019, 04:44 PM   #9
Ideucev8
Thanks Glenn. This is why i'm confused, when I had the Mack Products bed shipped down under they sent 2 countersunk bolts with it. I emailed them to ask about these bolts as the bed deck has no counter pressings in it & they told me 32 decks don't have those bolts.
Thanks, Phil
Old 07-07-2019, 07:03 AM   #10
glennpm
glennpm's Avatar
Hi Phil,
I'm guessing that they neglected to press for the countersunk bolts. You could probably do it. Back up around the underside of the bed with a plate or piece of hard wood having a hole slightly larger than the countersunk bolt head diameter. A combination of drawing the bolt tight and hitting it with a hammer may be sufficient. There are tools to do this too. A lot depends on how hard the bed sheet metal is.
Does one of the bed slats cover the head? You could also just use a hex head bolt and provide a pocket on the back side of the slat to accept the head.
Glenn
Old 07-07-2019, 07:44 AM   #11
DavidG
DavidG's Avatar
The only wood in an original '32 pickup bed is beneath the steel floor; there were no slates on top. Some add wooden slats above to cover up rust issues in the original steel floor.
Old 07-07-2019, 07:45 AM   #12
glennpm
glennpm's Avatar
Thanks David for the correction.
Glenn
