12-01-2021, 10:00 PM | #1 |
32 Ford Knobby Tires
Has anyone found a set of knobby tires for 32 Ford Wheels? I have a 30/31 Doodlebug that from the little history I have on the vehicle last had USED tires installed in 1969. They are ROCK solid. They are more like hard plastic than rubber at this point. It mostly used now for picking apples and running around the field. The car cannot get up the paved driveway in wet weather and it's not what you would call steep. Probably less than 18 degrees. I'm looking for some new rubber. Any suggestions? The current tires resemble these but with any inkling of tread in the middle worn away. Ignore the modern Rim
Weirder still even though all of the rims are 32' one tires somehow has a different diameter than the others. I think its got a 17" tire on there. |
12-01-2021, 10:17 PM | #2 |
Re: 32 Ford Knobby Tires
maybe some non directional military tires?
12-01-2021, 10:29 PM | #3 |
First, you measure a rim where the bead sits, not the overall diameter. Example, a 16" rim for a 16" tire would measure about 17" + . Next, a "knobby" is not a snow tire like you show. real knobby's are still made from Coker, but only in 16" sizes I believe. If you only use it on site, why not an agricultural tire? My old Kubota uses a 700/16 traction tire on the front. Now, about the "18" 32 wheels", is that really whats on there? On a model A ? If so, ford wire wheels in several sizes will fit your hubs...maybe, can we see the hubs?
12-01-2021, 11:32 PM | #4 | |
Stock Model A Hubs with 32 Ford Rims Most certainly. I'm Much better with A's than B's/18s. I will look at the Kubota tires. |
12-02-2021, 12:41 AM | #5 |
For fun, an example of my mighty 50 year old kubota hard at work like usual . These tires are available new, 16" for sure, never looked for others.
12-02-2021, 04:57 AM | #6 |
12-02-2021, 06:26 AM | #7 |
I had petrified tires on my 07 model R
used a sawzall to cut them off.................. another thought- 15 inch rims for your doodlebug would be easy and inexpensive to bolt on and buy tires for. I recently bought a 29 roadster and 15" mercury rims were on it. I have snow tires in 16 on the back of a "hot rod" A cabrio. One of the tires is dry rotted and I am facing the same problem. I will probably just bolt on a regular set of tires. Like the look of the snow tires for TROG on the beach though.... |
12-02-2021, 05:32 PM | #8 |
You would probably be better off getting some 15" or 16" rims that you can get "modern" tires on. I have a set of 16" snow tires you could have for a small fee if you want to come up to CT to pick them up. They are weather cracked, but still have a bunch of tread left.
Red |
12-02-2021, 10:23 PM | #9 | |
12-02-2021, 10:25 PM | #10 | |
12-03-2021, 08:47 PM | #11 |
Think Coker has them. But maybe why you are asking for alternatives. I run 16 - 700 military ndt 6ply on my truck. Love them. Lot more options with a 16" wheel
https://www.cokertire.com/tires/styl...and-truck.html Looks like the only 17" tire they have is a 17-750. big tire. https://www.cokertire.com/tires/750-...on-10-ply.html Hope you find what you are looking for! Last edited by Tinker; 12-03-2021 at 08:54 PM. |
12-03-2021, 10:24 PM | #12 |
Switching to 16" wheels would open up lots of options. I like the real knobbys, had them on my hotrod model A roadster.
12-04-2021, 08:38 PM | #13 |
I have two NOS "old school" 18" knobbys and two used ones. I don't know if it is practical to ship them. They are quite heavy. Jim in San Jose.
