03-22-2024, 07:35 AM | #1 |
Re: '37 Body mounts / Door alignment
Just snug bolts up without crushing the mounts. After a while go back and check them as some will need to be tightened as body compresses mounts. For the sagging door try installing thinner mount in the hinge area which will tend to bring other end up. I had a similar situation on my 39 and that cured it.
