06-27-2012, 03:40 PM | #1 |
pop-out switch installation problem - SUCCESS
I am attempting to install an original pop-out switch in my 28 and have a problem. Everything went fine until I I tried to mount the switch in the dash panel. This was the final step. The switch body seems to too big to fit into the round mounting bracket on the rear of the dash panel. Are there different versions of the panel? The mounting bracket appears to be original but after 80 years who really knows. Any help woulf be appreciated since I am unable to start the car as it sits now.
Thanks, Supergnat Last edited by supergnat; 07-01-2012 at 06:21 PM. Reason: Fixed problem |
06-27-2012, 04:29 PM | #2 |
Re: pop-out switch installation problem
There is also differences in the pop out switches, from year to year. You will need the correct one for your car..
06-27-2012, 05:35 PM | #3 |
A picture of both the switch and instrument panel would help with an answer.
06-27-2012, 05:37 PM | #4 |
{THIS WAS THE FINAL STEP}? Should of been the first step.. Easy to screw the pop out first on to the dash then speedo and then wires. Send the pop out down the gas tank tube and thru the firewall / term. box. Do the dist. and last the nut on the clamp on your pop out cable to the head.Yes and there are different heads on the pop out.Its a bitch !.
06-27-2012, 07:27 PM | #5 |
Peters180 A, you are correct. If I had tried to mount the switch initially I would never have proceeded further.
I have attached photos of what I have. When I checked the standards manual I found that probably have a switch for mid 29 or later. The standards manual does not mention the dimension of the actual switch body. The switch body measures 1.545 inches between the outside edges of the flanges that the screws thread into (not including the screws. The ID of the bracket that the switch slips into is only 1.495 inches in diameter. The switch will not fit into that small opening. I also measured the dash panel for a 31 A which belongs to a friend and it is the switch mounding bracket is the same dimension as mine. I don't know what to do next. I can put the non-popout back in or I could file .020" of each or the protruding switch mounting flanges on the recently acquired pop-out. Oh, I did hook everything up and found that the switch performs perfectly but will not mount in my panel. What are your thoughts. Thanks, Supergnat |
06-27-2012, 07:36 PM | #6 |
06-27-2012, 09:49 PM | #7 |
I agree with Jerry. You have the correct early style popout to be used with the oval speedometer. Did you have the screws removed when you tried to fit it?
06-27-2012, 09:56 PM | #8 |
I had trouble installing my (round speedo) 1930 pop out . It would screw up ok but then the panel wouldn't fit back in place . It was a repo panel and I brought an original panel on ebay and then no problems with installation
06-27-2012, 11:11 PM | #9 |
I`m thinking the panel could be a reproduction and a lot of them will not except the original pop outs with out some work.
06-28-2012, 06:09 AM | #10 |
I only installed the mounting screws in the switch so I wouldn't loose them. I tried to fit the switch in the panel with the screws removed. I think my panel is original and the dimensions of the bracket are the same as a panel from a friend's 31. I really want to use it so I will probably file the flanges later today or tomorrow so the switch will slip in the panel. Thanks again for all the help.
Supergnat |
06-28-2012, 06:30 AM | #11 |
I have taken a die grinder and removed some material from the dash panel, and the pop fits right in .
Mike |
06-28-2012, 06:30 AM | #12 |
If i remember you can only install two of them and the third which i believe is the top screw must be put in use a screwdriver that has been magnetize
06-28-2012, 06:41 AM | #13 |
I believe JW Hash may be correct. I very well could be wrong, but the "flat spot" on the top of the pictured panel appears to be larger than an original part. I just measured three original "nickel" panels and the receiver holes all measured 1.503". You may also find that your panel does not exactly line up with the four mounting holes in the tank. An original panel fits perfectly.
It is also obvious that the pot metal switch has "grown" as indicated by the cracks. It certainly won't hurt to reduce the diameter of your switch. As a purist, I would consider looking for an original panel. Gar Williams |
06-28-2012, 07:18 AM | #14 |
Are there any other wasy to identify a repro panel? This appears to be nickle plated. It was a pain to get in place even when the non-popout switch was installed on the panel but once under the dash overhang the screws line up perfectly. I don't know of anyone near by with an original pop-out that I could measure.
06-28-2012, 08:46 AM | #15 |
I would unscrew the switch from the distributor, file down the switch to fit, fasten to dash, screw distributor onto cable. My view of the picture may not be accurate, but the instrument panel looks OK. My original and repo panels are tucked away in storage or I could tell better. Someone with more experience than me should be able to tell for you sure.
06-28-2012, 12:52 PM | #16 | |
07-01-2012, 06:26 PM | #17 |
Re: pop-out switch installation problem - SUCCESS
Hi Everyone,
I successfully installed my pop-out. It wasn't easy but it is done. I had to file down the flanges to allow the switch body to fit into the mounting bracket in my dash. I assume the problem was due to swelling of the switch casting since switch mounting bracket on my dash measured the same size as a dash which belongs to a friend of mine. Thanks for your help as usual. Supergnat |
07-01-2012, 06:51 PM | #18 |
Glad to hear you got it figured out. Your dash panel looks like an original to me, based on your photos. It has the correct flat top for an early 28.
07-01-2012, 09:09 PM | #19 |
The ammeter gauge could use a little rubber silicone just to hold it level so it doesn't spin all catty wompus.
07-02-2012, 08:19 AM | #20 |
"catty wompus" That's a new one on me.
Paul in CT |
