Old 03-19-2012, 02:32 PM   #1
Scott H
Scott H's Avatar
Default What Grandpa or Farmer Brown used to do..
For some reason my 36 pickup has wide fives on the back and '35 spoked wheels on the front. I took off the hubcap to get to the spindle nut:
Yep, a good ol'fashioned bent nail instead of a cotter pin.
And another wheel apparently they lost the spindle nut and washer so they just put a huge nylock nut on there, no washer.
36 1/2 ton pickup
on 38 car frame
with 1940 v8 24 stud
Scott H is offline   Reply With Quote
Old 03-19-2012, 02:53 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: What Grandpa or Farmer Brown used to do..
There are plenty who are not Gandpa's or Farmers who did the same thing
Old 03-19-2012, 04:11 PM   #3
David J
David J's Avatar
Be thankful they didn't WELD the nuts on . Had that surprise once . Lotsa junk parts on that 34 . Coulda been the poster child for showing that some should not be allowed to have welders .
David J is offline   Reply With Quote
Old 07-23-2012, 06:53 PM   #4
Asphalt Outlaw Hero
Asphalt Outlaw Hero's Avatar
You mean everyone DOESN'T use nails .....?
Asphalt Outlaw Hero is offline   Reply With Quote
Old 07-23-2012, 10:13 PM   #5
alan
no, most true ford mechanics used bailing wire or wire from the closest fence
alan is offline   Reply With Quote
Old 07-23-2012, 10:29 PM   #6
Bob G/Spanaway
Bob G/Spanaway's Avatar
I've been calling baling wire "Ford parts" for at least 50 years.
Bob G/Spanaway is offline   Reply With Quote
Old 07-23-2012, 11:07 PM   #7
Tinker
Tinker's Avatar
The nail is okay in my book (basically its a bendable pin to elimanate movement), but the nylock nut... I dont know. Nylock nuts are ment to seal the first time, not so good the next time.
Old 07-24-2012, 06:21 AM   #8
jim1932
jim1932's Avatar
Mine had bent nails holding the door handles on.....
jim1932 is offline   Reply With Quote
Old 07-24-2012, 07:36 AM   #9
Cecil/WV
Cecil/WV's Avatar
I drove a truck for a guy in the '50's who had a '57 Mercury wagon and he couldn't keep the axles from slicing out of the wheel bearings, so he had them welded in. It never gave him any more trouble!
Cecil/WV is offline   Reply With Quote
Old 07-24-2012, 09:20 AM   #10
Bruce Lancaster
You gotta find OLD roofing nails, back storage room at a small town hardware or such. The Harbor Freight Chinese ones have plating that is TOTALLY incorrect for show judging.
Bruce Lancaster is offline   Reply With Quote
Old 07-24-2012, 09:24 AM   #11
David J
David J's Avatar
Sounds familiar - the 34 with the welded nuts was indeed operational . A mess but operational . On my old John Deeres you see this kinda stuff fairly regularly but they only go 6 mph if you put the spurs to em . Car is a different story & that is why the welded spindle nuts was kinda surprising . Yes I drove it around a bit before I found the welded nuts . That car ended up digested for parts . [1975] . The parts that weren't used for welder testing anyway . The front crossmember was pretty entertaining also - probably had more $'s worth of welding rod on it than a NOS one would have cost .
Old 07-24-2012, 09:26 AM   #12
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by bruce lancaster View Post
you gotta find old roofing nails, back storage room at a small town hardware or such. The harbor freight chinese ones have plating that is totally incorrect for show judging.
winner! dd
Click Links Below __
T5 W/TORQUE TUBE
Old 07-24-2012, 10:12 AM   #13
jim1932
jim1932's Avatar
Then there is the door bell on the dash....for my horn (Just above vacuum guage).
Old 07-24-2012, 12:45 PM   #14
FL&WVMIKE
FL&WVMIKE's Avatar
[QUOTE=V8COOPMAN;466813]winner! dd[/QUOTE
V8COOPMAN ................
Right-On, I, too, liked that comment from Bruce Lancaster.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 07-24-2012, 12:50 PM   #15
2935ford
2935ford's Avatar
or the one I like is welding the back of the lug bolts to the hub.
2935ford is offline   Reply With Quote
Old 07-24-2012, 12:56 PM   #16
Bruce Lancaster
Early V-8 Club needs to add a "Farmer" or "Great Depression" class for judging...
"Hey! My '32 earned an "Tom Joad" at the Nationals!" It only took second in "Best electrical fire", though. Maybe next year..."
Old 07-24-2012, 01:05 PM   #17
SUHRsc
SUHRsc's Avatar
Count me in on that Bruce!
I once got a trophy for "oldest dry rot".... seriously!
My car sat through the entire jalopy-rama with a flat tire!
-WANTED-
Pre-War Speed Equipment
Davies or Morrison Intake Manifold
77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads
SUHRsc is offline   Reply With Quote
Old 07-24-2012, 02:39 PM   #18
jim1932
jim1932's Avatar
OH GAWD... it would be just like Rat Rods.... guys messing up perfectly good stuff to make an award winning "Farmer Fix".
Old 07-24-2012, 03:24 PM   #19
Mike51Merc
Mike51Merc's Avatar
Hey, with the price of cotter pins you gotta give credit to the improvisers.
Mike51Merc is offline   Reply With Quote
Old 07-24-2012, 03:32 PM   #20
Bruce Lancaster
Yeah...some of the Model A frequently used to have a "worst in show" award that was eagerly pursued with stiff competition. Everyone who had an unrestored car would load it up with washtubs and kerosene lanterns and play Okie.
