03-21-2011, 07:49 AM | #1 |
cowl band clips
On a 30 / 31 tudor, under which screws go the clips to hold the cowl band down. most references just say the top screws but I cannot see where going right next to the hood retainer makes sense. would they go to the outer screws before it starts the curve downward? Using an aftermarket band, if that helps.
03-21-2011, 08:45 AM | #2 |
Re: cowl band clips
The early bands had several unique features. They were longer, extending to the edge of the body, they were held on with carriage bolts thru the cowl, and they used the clips on the tank to position the band. I don't know if all these features changed to the later style at the same time. |
