Old 08-19-2020, 08:34 AM   #1
1931 flamingo
1931 flamingo's Avatar
Default Interesting No Knock
Old 08-19-2020, 09:10 AM   #2
jetmek
Default Re: Interesting No Knock
What could go wrong��
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 08-19-2020, 09:46 AM   #3
Big hammer
And I have some land for sale in Florida :-)
get a bigger hammer tap done
Old 08-19-2020, 10:09 AM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Actually, several engines (mostly stationary) used this spring set-up with reasonable success. The only issue I see using the one in the pictures is the lack of a dipper for oiling. On the other hand, Model-T's did not use dippers from the factory.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-19-2020, 11:02 AM   #5
Ruth
The ad is for the bolts only. I assume you use your con rods that would have the dippers?
Ruth
Old 08-19-2020, 11:07 AM   #6
ursus
At least the advertisement doesn't claim that it gives the engine more power.
ursus is offline   Reply With Quote
Old 08-19-2020, 11:57 AM   #7
Purdy Swoft
Purdy Swoft's Avatar
If it gave it more power , I suppose that would cause it to become a hot rod .
Old 08-19-2020, 12:02 PM   #8
J Franklin
J Franklin's Avatar
This ad was for the Model T engines.
Old 08-19-2020, 06:29 PM   #9
1930-Pickup
cancel
1930-Pickup is offline   Reply With Quote
Old 08-20-2020, 06:03 AM   #10
BRENT in 10-uh-C
OK then, how do you propose to replace the rod bolts in an A/B rod??
BRENT in 10-uh-C
Old 08-20-2020, 06:05 AM   #11
BRENT in 10-uh-C
Yes, I agree with you.
BRENT in 10-uh-C
Old 08-20-2020, 07:34 AM   #12
Jack Shaft
Connecting rods are in compression during operation,main crankshaft bearing caps are in tension.What that means is the connecting rod is pressed against the crankshaft journal when running,the rod cap does not see the load of operation.On the other hand,the main bearing caps bear the load of converting linear to rotational force.Spring load main caps and the results wont be pleasant..Connecting rod as a dipper?how? even back then they understood the concept of windage,drag as little as possible through the oil for lubrication,drag too much and the oil acts like a brake.
Jack Shaft is offline   Reply With Quote
