06-11-2020, 09:36 AM | #21 |
Re: Slightly bent flange on a '40 rear hub- Can this be straightened?
i have cut off a couple axles to try and make an arbor to cut the inside of the drums. put a center in the cut off end for the tail stock, and grab the nut with a 3 jaw. never had one run true enough to work. your idea Brian, would work
