Old 06-02-2020, 10:23 AM   #1
Tim Ayers
Default Difficult time getting gas gauge bezel off
Hi All:
Like the title states, I'm really having a tough time getting the gas gauge bezel off. I've been soaking it for a week with rust buster and and 50/50 of ATF & Acetone and it's not budging.
The tank as been empty for a very long time and I was thinking of using a plumber's torch to gently heat up the bezel to see if that will break it free.
Any other thoughts on how to free it up? Its a perfect original so I'm trying not to damage it.
** PS- I do have the correct "wrenches" for removing this.
Thanks,
Tim
Old 06-02-2020, 10:34 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Difficult time getting gas gauge bezel off
Tim, we have had them come in where we had to use an air hammer with a chisel to remove the outer ring because it was froze. Then you can sometimes use a little air pressure (i.e.: 5#) with the tank ports sealed to help push the gauge away from the seat.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 06-02-2020, 12:09 PM   #3
Tim Ayers
Interesting idea. Thanks,
Old 06-02-2020, 12:10 PM   #4
redmodelt
redmodelt's Avatar
Think about it dude, open flame and gas! Even the vapors from a dry tank...BOOM!!!
Old 06-02-2020, 12:57 PM   #5
1930 coupe
I had to use a large pipe wrench one time to get one off.
I had to replace the bezel with a new one after that because the wrench made deep marks in it.
1930 coupe is offline   Reply With Quote
Old 06-02-2020, 02:11 PM   #6
Tim Ayers
That's why I asked. When I say dry, it's been dry and capless for over 25 years.
I'd love to get it off without damage since it's original to the car '28 AR Roadster
Old 06-02-2020, 02:30 PM   #7
redmodelt
redmodelt's Avatar
d Even a "dry" tank that old has the potential to go boom.
I have see shots of guys, with helpers (one to push in on the tool and one to turn the cheater bar) that used a long cheater bar on the bezel tool and still had a hard time cracking it loose. If you have the good tools, you stand a chance, if they are those aluminum die cast ones, good luck they barely work on ones that the gauge is not stuck.
Poor;
https://www.snydersantiqueauto.com/P.../model-a/tools
Better;
https://www.snydersantiqueauto.com/P...GAUGE-TOOL-SET
Old 06-02-2020, 02:52 PM   #8
Tim Ayers
Thank you. Yep, I've got the cast one. It is a flimsy tool. haha,
Old 06-02-2020, 03:11 PM   #9
john charlton
john charlton's Avatar
Use the laser cut flat steel one (it does have a kink in it )it does not slip off like the cast aluminium one does .
John in real lovely Model A Ford driving weather but I cant not yet Suffolk County England .
john charlton is offline   Reply With Quote
Old 06-02-2020, 04:53 PM   #10
wmws
Before putting a flame by that tank pump it full of carbon monoxide from a good old polluting car. No BOOM.
wmws is offline   Reply With Quote
Old 06-02-2020, 07:10 PM   #11
larrys40
You can try a heat gun ( no flame!) to heat the outer ring a little. Should be safe as long as tank isn’t leaking fuel. Best if it’s an old tank that hasn’t had fuel in it for a while. fuel weeping at the gauge causes the outer ring to get stuck. A little penetrant can help as well. The original ford 5z gas gauge wrench works best .
Have done many and typically my wrench does the trick .
Larry shepard
larrys40 is offline   Reply With Quote
Old 06-02-2020, 07:13 PM   #12
updraught
updraught's Avatar
If it is a new alloy one it is useless. Use the steel one.
http://jmodela.coffeecup.com/fixgasgauge.html
updraught is offline   Reply With Quote
Old 06-02-2020, 08:26 PM   #13
Tim Ayers
Larry shepard
Thank you. I was thinking maybe heat gun too.
Dang. That is a great looking tool. I'd love to get one if anyone has one for sale.
Old 06-02-2020, 09:12 PM   #14
1crosscut
1crosscut's Avatar
Dry and capless for that long it isn't going to go boom. Stick your nose in the filler neck and give it a sniff. You'll be able to tell.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 06-02-2020, 10:33 PM   #15
Synchro909
Synchro909's Avatar
Those cast aluminium tools are designed to skin knuckles!
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 06-02-2020, 11:41 PM   #16
ursus
They are actually useful for installation but doubtful for removal. My experience is to chisel the bezel off, use the aluminium tool for installation, then throw it away.
ursus is offline   Reply With Quote
Old 06-03-2020, 05:20 AM   #17
Synchro909
Synchro909's Avatar
I made my own pair of tools out out steel. I've used them and loaned them lots of times and they are just as good as the first time. Aluminium is NOT the material to use for something like this. Cheap and nasty!
Old 06-03-2020, 08:31 AM   #18
vern hodgson
I put a torch on a one gallon gas can, had been sitting in the desert for nigh on to twenty five or more years. Surprise, small boom, cheap lesson learned.
vern hodgson is offline   Reply With Quote
Old 06-03-2020, 09:17 AM   #19
Badpuppy
Impact driver would do the trick if there were a 10-point socket for it.
Wouldn't It Be Nice...Drifting and Dreaming...ZZ-Z-Z...
Badpuppy is offline   Reply With Quote
