Old 09-06-2019, 04:05 PM   #1
coolcoupe
coolcoupe's Avatar
Default front brakes
Wondering what years car/truck front brake drums will fit my 47 car?
coolcoupe is offline   Reply With Quote
Old 09-06-2019, 04:15 PM   #2
Mart
Mart's Avatar
Default Re: front brakes
Repro drums are available.
You could fit some of the lincoln types that are available.
You could go F100.
The last two would be complete brake swap outs, not just a drum.
What are you trying to do?
Mart.
Old 09-06-2019, 04:39 PM   #3
19Fordy
19Fordy's Avatar
Like Mart said, these MT Products drums will work but, you will have to use new hubs and best to reuse your old bearings.
Old 09-06-2019, 05:09 PM   #4
RalphM
RalphM's Avatar
I thought you could use the MT drums on your exsisting 47 hubs?
Only require new studs, which MT can supply. Old studs will have to have drum swage cut, or drill the studs out.
RalphM is offline   Reply With Quote
Old 09-06-2019, 05:15 PM   #5
19Fordy
19Fordy's Avatar
RalphM: My error. You are correct. You can reuse your old hubs if you install new studs.
I don't know if MT sells the studs.
Old 09-06-2019, 05:20 PM   #6
Charlie Stephens
According to the Green Bible the front hub/drum assemblies fit 1940 to 1948. Although they are different from the front the same applies to the rear. If you take them apart the pre war hubs must be used with the pre war drums and the post war hubs must be used with the post war drums.
Charlie Stephens
Old 09-06-2019, 05:31 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
1940-'48 drum/hub assemblies from an automobile, as well as drum/hub assemblies from '40 AND '41 pickups. !940-'48 Mercury drum/hub assemblies will also swap-out. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 09-06-2019, 06:20 PM   #8
coolcoupe
coolcoupe's Avatar
So 42- 48 p/u drums won't fit my 47 car?
Old 09-06-2019, 10:02 PM   #9
rich b
rich b's Avatar
If you are talking hub/drum assys; up to '47 will fit. '48 up used 11" Bendix brakes.
If you are talking drums only, you need to get the ones that fit your style hub; flange inside or flange outside.
If you have the outside flange style and you want to replace the drums; best bet would to get some inside flange hubs and new MT (Boling Bros) drums as posted earlier.
rich b is offline   Reply With Quote
