Old 06-29-2019, 07:44 AM   #1
Trekemeyer
Default 36 ford transmission shifter very slopy
Replaced.my transmission with a used one looked inside everything looked good but when I got it together I found the shift handle very sloppy had to use the handle off my transmission was wondering if anyone had any input on what needs to be done or replaced thanks Tom
Trekemeyer is offline   Reply With Quote
Old 06-29-2019, 08:44 AM   #2
Russ/40
Russ/40's Avatar
Default Re: 36 ford transmission shifter very slopy
Restore the ball size on the shifter, and the gates in the forks. That will take care of it. Also, the longer the shift handle, the looser the shift will feel.
Russ/40 is offline   Reply With Quote
Old 06-29-2019, 09:19 AM   #3
Ole Don
Ole Don's Avatar
Weld up the slot and file it back to fit the hardened pin.
Ole Don is offline   Reply With Quote
Old 06-29-2019, 09:43 AM   #4
40cpe
40cpe's Avatar
Ole Don, can you elaborate on what tool to use to file the slot after welding? I have one that needs closing up and am not sure how to accomplish getting the slot back to a uniform size. I was thinking it might be a job for a machine shop.
40cpe is offline   Reply With Quote
Old 06-29-2019, 09:54 AM   #5
JM 35 Sedan
JM 35 Sedan's Avatar
In addition to restoring the slot in the shifter, the pin could be worn as well as the hole for the pin in top of shift tower.
John
Old 06-29-2019, 10:57 AM   #6
Mac VP
Mac VP's Avatar
The hole in the top of the shifter tower is somewhat difficult to repair if it’s worn but it’s doable. We have the repair tips for the lever itself here:
http://www.vanpeltsales.com/FH_web/f...ems-levers.htm
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 06-29-2019, 11:08 AM   #7
deuce_roadster
deuce_roadster's Avatar
My friend with a Bridgeport mill cuts new slots in levers for me after welding them up. Accurate and perfect parallel sides.
Old 06-29-2019, 01:56 PM   #8
Charlie Stephens
Did you remember to put the pin in that aligns the lever? If it is missing it may be in the transmission and you had better find it before the gears do.
Charlie Stephens
Old 06-30-2019, 09:52 AM   #9
richard crow
for the shift lever slot take a drill bit set & try a bit that fits tight in the slot use the chuck end not the cutting end.now reverse the bit drill the tower to that size .now reverse the bit again & push the chuck end in measure & cut it to the lenth needed use a die grinder to cut the bit. or have the sloth welded & then bring to a machine chop & have a new slot cut between the welding & machine work expect to spend over a hundred dollars
richard crow is offline   Reply With Quote
Old 06-30-2019, 03:02 PM   #10
FlatheadTed
FlatheadTed's Avatar
The pin is not really a precision item ,we did a 29 Chrysler that the shift was all over the place ,we migged up the sides of the slot then recut it with a cut of wheel, nice shift after that
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 06-30-2019, 07:35 PM   #11
Trekemeyer
Checked all the different problems you guys thought it could be and it turns out the hole in the tower is very worn this shift tower is a 40-7222 and is called a slant back style the other tower I have is a 38-7222 it shifts great but the shifter fork is not the same size so I thought maybe someone might make an oversized pin to repair this problem or find a shift tower from someone on the barn and just replace it thanks Tom 518 573 7447 if someone has the part
Old 06-30-2019, 08:07 PM   #12
tubman
tubman's Avatar
Unless i"m mistaken, that "shifter fork that is not the same size" is the valuable later part used to put stronger, later model gears in the transmission. Don't lose it.
tubman is online now   Reply With Quote
Old 07-01-2019, 05:42 AM   #13
Mac VP
Mac VP's Avatar
I suspect that you meant to type that you have a 68-7222 shifter housing. This could be used on your 32-35 gearset with one change. You would have to replace the B-7100 low/rev gear with a 67-7100 gear (has straight cut gear teeth but a larger diameter fork flange) to match the larger low/rev fork in this tower. Unless someone has changed out the 2nd/high fork, it will already be correct for your gearset. Lastly, the 68-7222 tower will require that you open up the hole in the transmission cover sheet metal to clear the top of the upright tower.
Don’t be tempted to grind the tips of the existing low/rev fork in the 68 tower. You could make it fit your early type gear fork groove but the fork tips would look like toothpicks when you got done grinding.
VANPELT SALES LLC
Cincinnati, Ohio
Old 07-17-2019, 04:05 PM   #14
badassfrombadaxe
I had asked about the 7206 Housing guide pin over in Early Ford group and they referred me to Ford Barn where they said you occasionally post. I think this pin guides the second and high shifter fork so it does not lean and the fine synchro-teeth engage well. It appears to be on all Ford 3-speeds from 1932-1939, including Model B. It does not appear to be in Model A. Until, I had looked at some Model A and Model B photographs of shifters and also went to your site and saw you sell the whole 7222 where this would be an included part I did not wish to trouble you. I have your book and the Ford Green book both of which have no more information on this part. Thanks for the courtesy.
badassfrombadaxe is offline   Reply With Quote
Old 01-30-2020, 02:55 PM   #15
macdonge
macdonge's Avatar
Badassfrombadaxe: Did you ever get a reply regarding a source for this part, i.e. B-7206 Guide Pin? I'm taking a transmission apart right now and will need a replacement. Thanks!
macdonge is offline   Reply With Quote
Old 01-31-2020, 05:27 AM   #16
deuce lover
deuce lover's Avatar
I'm sure Third Gen Auto has them.
deuce lover is offline   Reply With Quote
Old 01-31-2020, 09:34 AM   #17
35fordtn
35fordtn's Avatar
You can use a b-7155 pin and cut it down after installation
35fordtn is offline   Reply With Quote
Old 01-31-2020, 12:02 PM   #18
macdonge
macdonge's Avatar
That's was my 'plan B' 35fordtn. Mac VP also suggested it but said 'plan A' should be to try and reuse the original pin (presumably since it's tapered at one end). Mine is bent slightly so I'll see if it can be straightened out first. Thanks!
