Old 07-15-2018, 09:58 AM   #1
Tinbasher
Tinbasher's Avatar
Cool Late 31 Cabriolet Run Channels
Hi Guys:
I'm working on a late 31 Cabriolet with "Steel Doors" My question is? How are the window run channels held into the channels? Are they like a coupe and use the metal clips on the top and bottom or are they glued in or just work on friction. Pictures from the "Cabriolet Guys" would be great.
Thanks John Poole
Tinbasher is offline   Reply With Quote
Old 07-15-2018, 03:54 PM   #2
larrys40
Default Re: Late 31 Cabriolet Run Channels
John
Glad you ask.... I will have that job ahead of me as well when I get going on mine.
I got window channels from bill Underwood
larrys40 is offline   Reply With Quote
Old 07-16-2018, 05:09 AM   #3
Oldbluoval
Oldbluoval's Avatar
Yes I have them and some other a400 and cabby parts
[email protected] for list
Oldbluoval is offline   Reply With Quote
Old 07-16-2018, 08:35 PM   #4
Tinbasher
Tinbasher's Avatar
Thanks for the posting guys but I'm looking for info. Pictures anything that will help to install the channels. I have the channels.
JP
Old 07-17-2018, 05:08 AM   #5
Oldbluoval
Oldbluoval's Avatar
There are three screw holes in the channels and three d-nuts in the door
You simply attach the long channel with the theee screws
6-32 flat head as I recall
One in the bend and two toward each end
Old 07-17-2018, 06:50 AM   #6
Tinbasher
Tinbasher's Avatar
Thanks Oldbluoval. That gives me an idea of where I'm heading. JP
Old 07-17-2018, 08:46 AM   #7
Oldbluoval
Oldbluoval's Avatar
If you have original channels, the screw holes are almost always broken out. Then it's impossible to put a small screw to hold them. I have no solution for that unless some washer-type set up. You can't weld on them as the felt would burn.
Old 07-18-2018, 06:32 AM   #8
Tinbasher
Tinbasher's Avatar
I have new channels. The trick is are they going to work.
Old 07-19-2018, 07:22 AM   #9
Oldbluoval
Oldbluoval's Avatar
PM sent
