12-23-2017, 05:12 PM | #1 |
Bearing removal from differential carier
Getting started to rebuild rear end and first thing is replacing bearings in the two carrier halfs of the differential. I don't have any kind of a puller and really don't know how one would work. Any ideas how to get them out? Thanks, Jim
12-23-2017, 05:42 PM | #2 | |
Re: Bearing removal from differential carier
Bill |
12-23-2017, 05:54 PM | #3 |
For the carrier bearings see page 16 of Tom Endy's article at this link.
http://www.santaanitaas.org/wp-conte...vised-2014.pdf Bob |
12-24-2017, 12:51 AM | #4 |
12-24-2017, 01:06 AM | #5 |
For many years, I have been driving out the bearing cups from the rear axle housings with a long piece of cold roll steel. I have had to grind the cold roll rod for the best fit on the bearing cup. Not much of a bearing lip to drive against, but it has been working for me. I think that I can drive a bearing cup out faster than the fellow in the video that was welding a bolt to the bearing cup and then using a slide hammer puller to pull the bearing cup out.
12-24-2017, 05:39 AM | #6 | |
12-24-2017, 12:23 PM | #7 |
Good information but he is asking how to pull the bearing off the carrier, not out of the housings.
If you don't have the tools I would suggest taking to a shop along with your new ones and have them pressed off and new ones installed. Same with the first pinion bearing.
12-24-2017, 01:56 PM | #8 |
I cut the cage with dikes and remove all the rollers,then take a small cutoff wheel and cut a diagoinal slot in race but not so deep to get into carrier. then take a small chisel into the grove you cut and split race. done
12-25-2017, 07:36 AM | #9 |
I do the same thing here except dikes here in England are sidecutters . Actually here a dike or dyke is a lady on the masculine side who likes fems ,ladies on the feminine side . Even more masculine ladies are bull dykes they favour leather jackets and short haircuts .
It is good news if you have to pull off the bearing ,a lot of them just fall off. In Merry Xmas Suffolk County England . |
12-25-2017, 12:25 PM | #10 |
Different spelling, John.
Use the chisel against the carrier housing, or locate a three leg gear puller. They are a useful tool to have. |
