Old 08-04-2015, 08:04 PM   #1
Lawrie
Lawrie's Avatar
Default Shock ID
I have these in my pile,they don't fit my 33 or 34,would any one know what they fit.
Thanks Lawrie
Lawrie is offline   Reply With Quote
Old 08-04-2015, 09:44 PM   #2
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: Shock ID
Lawrie, it might help to see some side views, and mounting end views, know the length of the arms and their part numbers, the diameter of the shock body, plus knowing the center to center distance between the mounting holes would all be good info to help ID these.
John
Old 08-05-2015, 05:59 AM   #3
BILL WZOREK
BILL WZOREK's Avatar
X2 what John said / also arm #'s
BILL WZOREK is offline   Reply With Quote
Old 08-05-2015, 08:46 PM   #4
Lawrie
Lawrie's Avatar
More pics,John ,I forgot to measure the arms,
Lawrie
Old 08-06-2015, 05:18 AM   #5
BILL WZOREK
If the body's are 3 1/4" Diameter they 1947 / 48
Old 08-06-2015, 05:59 AM   #6
Terry,OH
Terry,OH's Avatar
The earlier style is slightly smaller in diameter. I believe Ford went to the larger diameter shock body in 41. If the arms have the number 10 embossed or stamped into the arm at the small reinforcement they are 1940 fronts. The screw on caps on the main body were changed in 38-39 for the spring loaded seal (what you have).
Old 08-06-2015, 06:20 AM   #7
BILL WZOREK
Smaller body = 2 7/8" diameter
Old 08-06-2015, 04:16 PM   #8
Lawrie
Lawrie's Avatar
Thank you guys,
I will off load them as they won't fit any of my cars 33 &34.
Lawrie
Old 08-06-2015, 04:50 PM   #9
JM 35 Sedan
Lawrie
Lawrie, Thanks for posting additional pictures. I am glad others chimed in on the ID because I was still not sure what year they are for, other than knowing they were not '35 or earlier.
John
Old 08-06-2015, 05:02 PM   #10
Lawrie
Lawrie's Avatar
OK John, I,m going down to Brisbane later in the month for our clubs swap meet ,so will see if some one there needs them.
Lawrie
