Old 04-28-2013, 01:34 PM   #1
Jim/GA
Jim/GA's Avatar
Question Does the coil need to be grounded?
When mounting the coil to the firewall, do I need to make sure it has a good ground? As in, sand some paint off of the firewall and off of the mounting bracket to get bare metal on the two touching.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 04-28-2013, 02:07 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Does the coil need to be grounded?
No ground needed. The coil body has no connection to the insides.
Old 04-28-2013, 02:46 PM   #3
Jim/GA
Jim/GA's Avatar
Cool. Thanks.
I seemed to remember seeing guys run an engine on a chassis with no body by mounting a piece of plywood on the chassis to hold the coil and a temporary fuel tank... but they could have run a ground wire that I could not see.
Jim Cannon
Old 04-28-2013, 02:48 PM   #4
Patrick L.
Patrick L.'s Avatar
The only ground the coil needs is thru the points on the primary lead. [ insert smiley face here].
