09-29-2020, 05:56 AM | #21 |
Re: Distributor Removal Tip Re Ignition Cable Clamp
If they have to order it, ask what the freight charges will be; if high, see what they can do to reduce.
09-29-2020, 10:24 AM | #22 |
09-29-2020, 04:36 PM | #23 | |
Thanks again. Fastenal didn’t have them in stock, but they ordered me a couple. They should be in on Thursday. Sent from my iPhone using Tapatalk |
09-29-2020, 05:38 PM | #24 |
If my cars had a clamp like Bob's I would just bend it up till I changed things out and then bend it back down.
09-30-2020, 05:48 PM | #25 |
The cable is an anti-theft design, but I believe that thew clamp's purpose is to keep the cable from contacting the spark control rod.
Brent, I can change a distributor faster than you can change the points / condenser. You would also have to time the ignition. Changing the distributor does not require timing the ignition. Enough said. I rest my case!
Bob Bidonde |
09-30-2020, 07:44 PM | #26 |
10-01-2020, 07:54 PM | #27 |
I think I got mine at Home Depot or Ace Hardware.
10-01-2020, 07:55 PM | #28 |
That would work, except for the fact that the original clamp had both halves secured by the #8 head nut.
10-02-2020, 04:04 AM | #29 |
