Old 04-11-2020, 07:00 PM   #1
oneofone
Default What type vehicle is this part of?
It's a two door roadster but I'm not sure other than that. I would like a pic of a good piece like mine so I can fabricate this one.
oneofone is offline   Reply With Quote
Old 04-11-2020, 07:05 PM   #2
redmodelt
redmodelt's Avatar
Default Re: What type vehicle is this part of?
See photo below
Old 04-11-2020, 08:36 PM   #3
oneofone
Really? Door threshold clearly sathumbnail-1.jpgYS FORD.
Old 04-11-2020, 09:41 PM   #4
redmodelt
redmodelt's Avatar
Did a little checking after see the step plate. Looks to be 1926/27 roadster. The door openings looked to long for T from the angle shown.
Old 04-11-2020, 10:18 PM   #5
oneofone
Excellent, Thanks for your time and effort.
Would you know where I can get the dimensions so I can fix the rust at the bottom? I seen some patch panels on EBay but they don't look quite right. TY again, j
Old 04-11-2020, 10:37 PM   #6
redmodelt
redmodelt's Avatar
Sorry can't help with dimensions. The ones on eBay are more then likely from Howells. While it's hit and miss to order directly from them, the ones sold on eBay, they should have in stock. They may be a little off but would be something to work from.
Old 04-11-2020, 11:03 PM   #7
oneofone
Thanks
Old 07-31-2020, 04:34 PM   #8
jimvette59
jimvette59's Avatar
You should put the body together on the sub frame and assemble as built by ford. I don't think you can restore it piece by piece. I wouldn't try. JMHO
jimvette59 is offline   Reply With Quote
