Old 02-18-2019, 01:04 AM   #1
Tudortomnz
Tudortomnz's Avatar
Default Canadian tool mark
Do any of the Canadian guys know the name of the tool manufacturer of this Canadian monkey wrench? This mark appears on a number of late tools, eg. pliers & wrenches. Cheers- Tom in NZ.
Tudortomnz is offline   Reply With Quote
Old 02-18-2019, 01:11 PM   #2
Brad in Germany
Brad in Germany's Avatar
Default Re: Canadian tool mark
Here is the photo from Tom's .pdf file:
Brad in Maryland
Brad in Germany is offline   Reply With Quote
Old 02-19-2019, 11:28 AM   #3
Farrell In Vancouver
Farrell In Vancouver's Avatar
Could be from ETF Tools in Ontario but hard to see from your shot the trade mark.
Been around since early teens into thirties and fifties under different names.
Farrell In Vancouver is offline   Reply With Quote
Old 02-19-2019, 11:54 AM   #4
katy
katy's Avatar
You might try: http://alloy-artifacts.org/
Old 02-19-2019, 03:02 PM   #5
Don S
The judging standards show the wrench in question, early ones had Ford script , but later were made by several suppliers . Your wrench has an E inside a circle, no reference to that in the standards. They should be 9 3/8 " long with a square end on it for the differential plug. Hope this helps.
Don S is offline   Reply With Quote
Old 02-19-2019, 03:09 PM   #6
Don S
I should have mentioned that the Canadian portion of the standards do not indicate that the tools supplied to Canadian vehicles are different in origin than the American tools.
Old 02-19-2019, 03:57 PM   #7
160B
160B's Avatar
Here are copies of RG&JS F-29 Revised 2016 and F30 Revised 2016 for Canadian vehicles area 17 Tools
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 02-19-2019, 07:18 PM   #8
rotorwrench
rotorwrench's Avatar
The tools used by Ford of Canada with the E in a circle were made in Cleveland, Ohio by Eberhard Manufacturing Company.
http://www.wrenchingnews.com/wrench-...os-page-1.html
Old 02-19-2019, 08:43 PM   #9
Tudortomnz
Tudortomnz's Avatar
Thanks for the replies. All good info which I will look into.
I have looked through Alloy Artifacts but nothing on Canadian tool makers.
Also considered Eberhard but there were many toolmakers in Canada.
For '28-'29, Canada used mostly US toolmakers, but late production sees mostly local sourced items.
If anyone has a spare kit wrench [the larger one] marked E encircled, I would be interested in buying . Cheers - Tom in NZ.
Old 02-21-2019, 05:35 AM   #10
30ccpickup
30ccpickup's Avatar
I found this on another thread. May or may not be worth looking into.
" Made In Canada' appears on the 2 wrenches,[ previous usually no Ford script], ; an 'E' or 'E' encircled are Canadian [ Eureka, Ontario?] marks on unscripted items.. Also McKinnon supplied some items [ thistle logo] but were acquired by GM early '29."
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 02-21-2019, 05:41 AM   #11
30ccpickup
30ccpickup's Avatar
I see Rotorwrench already posted the correct answer in #8 and here I thought I was doing a good deed. Nice info thanks
Old 02-21-2019, 10:54 PM   #12
Tudortomnz
Tudortomnz's Avatar
Great info !
I think Rotowrench has nailed it. Eberhard was in Cleveland which when I looked at a map is not too far from Detroit & Windsor, just across Lake Eyrie.
Ford Canada used suppliers in Ontario but also in nearby US. The American companies could probably handle quick orders better than Canadian ones. Cheers. Tom in NZ.
Old 02-22-2019, 12:51 AM   #13
Synchro909
Synchro909's Avatar
I have one of those with no markings at all other than the Ford script and "Made in Canada" in the handle. Maybe no one wanted to own up to making it??
Old 02-24-2019, 04:33 AM   #14
Halswell
Old mate gave me the small spanner the other day. Has ford script and this on it.
V
<G-H> Never seen one like that before. Maybe from the UK?????? Happy Motoring.
P
Halswell is offline   Reply With Quote
Old 02-24-2019, 11:12 AM   #15
160B
160B's Avatar
V
P
"VP&GH" is a English manufacturer.
