Old 07-11-2018, 07:52 PM   #1
boo
Default 160 deg. thermostat questions
i'm puting a hot water heater in my A, non presurized radiator. inlet to heater out of water neck on head. WILL the unpresurized system push water throw the heater?? i thought about using a 160 thermostat between neck and rad. to give some pressure to divert some water to heater???? ALSO a friend said to drill some xtra holes in the thermostat to increase some more water flow thru it??? has a new radiator w/12 fin-inch, want to tour w/car.
boo is offline   Reply With Quote
Old 07-11-2018, 08:28 PM   #2
steve s
steve s's Avatar
Default Re: 160 deg. thermostat questions
Yes, the water pump will push SOME water through your heater, but it will do it a lot better if it's working against the slight back pressure from a thermostat. Plus, your water will be a lot hotter sooner with a thermostat; in my experience, without a thermostat your heater will be nearly useless (Michigan winter) even if there is lots of flow. A 180-degree stat will work even better, but a 160 is usable. Be sure your water outlet to the heater is between the water pump and the stat. I HIGHLY RECOMMEND the Vintage Precision thermostat block which has taps for heater hose and temperature gauge. THe block has small bypass holes machined in so it shouldn't be necessary to drill extra holes in the stat. I believe that I drilled a 1/8" hole in mine, just to be sure. The concern is that if coolant flow is TOTALLY blocked during warm up, local hotspots might occur, possibly causing vaporization, overflow blown back out the radiator overflow tube, and motor damage. Also, some flow by the thermostat's sensor pellet is good to be certain the stat is getting a good reading of the average coolant temperature in the head. Such bypass is in addition to that provided by the tiny hole stat flanges typically have to allow trapped air to bleed out should, for example, should any get trapped when coolant is added or changed.
File Type: jpg 2010 radiator replacement 002 - cropped.jpg (63.5 KB, 115 views)
File Type: jpg 2010 radiator replacement 001 cropped.jpg (74.7 KB, 129 views)
steve s is offline   Reply With Quote
Old 07-12-2018, 04:02 AM   #3
Bruce of MN
Bruce of MN's Avatar
OT, but what carb do you have there?
Old 07-12-2018, 07:34 AM   #4
steve s
steve s's Avatar
Zenith 13922
Old 07-12-2018, 08:33 AM   #5
jhowes
Is it my eyes or is your thermostat in backwards?? Jack
jhowes is offline   Reply With Quote
Old 07-12-2018, 09:17 AM   #6
Bruce of MN
Originally Posted by steve s View Post
Zenith 13922
Thanks
Old 07-12-2018, 12:26 PM   #7
CarlG
CarlG's Avatar
The spring goes to the engine side.
The pointy dealy-doo should be pointing at the radiator.
His pictures show the correct orientation.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-12-2018, 07:55 PM   #8
Doug_Knutson
This how I connected my inside hot water heater on my 29 Tudor running a B head and intake
Doug_Knutson is offline   Reply With Quote
Old 07-12-2018, 08:01 PM   #9
Doug_Knutson
Then the following pics show my temp shutoff valve (inside the cab at the floor level). Then the cold water returns into the lower rad hose .. sure is nice on those cold Alberta mornings
Old 07-12-2018, 08:02 PM   #10
Doug_Knutson
Then the view from the rear of the motor and where the upper hot water line enters the fire wall
Old 07-12-2018, 11:24 PM   #11
CarlG
CarlG's Avatar
Looks like you have both a hot water heater and a manifold heater!
Alaskan A's
Old 07-13-2018, 07:07 AM   #12
old31
Carl, there you go again with that technical talk "The pointy dealy-doo" Oh I am so confused.
old31 is offline   Reply With Quote
Old 07-13-2018, 09:04 AM   #13
Doug_Knutson
Old 07-13-2018, 09:08 AM   #14
Doug_Knutson
Yes - Sir My hot water heater is located under the drivers front seat, it is a small unit with the air exiting both side with the small 6 volt motor hang downward through a small round hole in the floor board. As stated it can get cool in the Rocky Mountains in the morning and make the Miss much happier
Old 07-13-2018, 11:21 PM   #15
Doug_Knutson
Oh - I should add that my thermostat is located inside the rubber hose .. I canít recall the details but I recall it was from a 80ís car and around 160 F .. My hot water takeoff is brazed onto the neck and results in lots of flow + there is A 1/8 inch hole drilled in the body to ensure it doesnít vapour lock .., zero problems in 8 years plus
Old 07-14-2018, 12:01 AM   #16
Mike V. Florida
Mike V. Florida's Avatar
Zenith 13922
To expand a little the carb is used on forklifts and the like and with the exception of the GAV will work the same in the A.
Here is an old discussion on the carbs;
https://fordbarn.com/forum/showthread.php?t=166462
