Old 01-17-2011, 10:19 AM   #1
George49Ford
George49Ford's Avatar
Default 302/351 2V Carb
Will a 351 2v carb work on a 302? That "site" has a 351 2V carb (D2OF-UB). It's a 1971 Torino w/automatic. Thanks, George M.
George49Ford is offline   Reply With Quote
Old 01-17-2011, 12:27 PM   #2
raceron1120
raceron1120's Avatar
Default Re: 302/351 2V Carb
If that D2OF-UB is/was on a '71 Torino it's likely a replacement for the original since that tag # indicates it's 72 (D2='72) carb. The tag crosses to a service replacement carb # D2AZ-9510-C, which according to the parts book I have, is for a 351W with manual transmission.
There was so much interchanging and replacing going on back in those days it's kind of tough to track them, and many carbs could be interchanged with a little fiddling around. If memory serves from my old parts department days the 2 most popular replacement 2 bbl carbs were the D2AZ-9510-C (351) and the D2AZ-9510-P, which I think was for the 302s and possibly earlier 289s at that time.
Ron
raceron1120 is offline   Reply With Quote
Old 01-17-2011, 08:41 PM   #3
George49Ford
I appreciate the info. Thank You.
Old 01-17-2011, 08:59 PM   #4
darrell
all ford 2bbl carbs from 57 up will fit with some frigging around.the early ones 64 and older will not have kickdown hookup.
darrell is offline   Reply With Quote
Old 01-17-2011, 11:39 PM   #5
junkyardjeff
It might be jetted too rich for your application.
junkyardjeff is offline   Reply With Quote
