01-19-2023, 10:43 PM | #1 |
Tink Tach - Update new P/N
Hi, has anyone used the Tiny Tach tachometer? If yes, did you like it? Or any problems with the unit?
Thanks. Tiny Tach Tech Support gave me a new p/n to order for Model A's. 1CRXL. We'll see how this works. Herb Last edited by Herb Concord Ca; 01-23-2023 at 04:05 PM. Reason: update |
01-19-2023, 10:52 PM | #2 |
Re: Tink Tach
I've used them for years. I like them, but I use them mostly as service minders. I have them on my lawn and garden equipment. Getting kinda pricey now days. There are some less expensive Chinese subs available that seem to work well. Just search Amazon and you'll find several substitutes.
01-19-2023, 11:08 PM | #3 |
Re: Tink Tach
I have them on 2 of my Model A's.
Like them, would highly recommend. Chris W. |
01-20-2023, 06:47 AM | #4 |
Re: Tink Tach
how does everyone attach the wire?
01-20-2023, 07:47 AM | #5 |
Re: Tink Tach
I bought a cheap digital tach a few years ago, but the poorly translated instruction didn't say how to set the dip switches to select 4 cylinder, etc. Is this addressed with other brands?
01-20-2023, 10:36 AM | #6 |
Re: Tink Tach
01-20-2023, 10:42 AM | #7 |
Re: Tink Tach
Well, yes, the manuals can be hard to understand. But, you know what RPM range you're looking for so just experiment with the few possible switch configurations until you have an RPM in the range expected. It's not like it's going to be off 20% if you have the wrong switch settings, it's going to be off by 50% or 100% so it's pretty easy to settle on the correct settings.
01-20-2023, 09:04 PM | #8 |
Re: Tink Tach
Possible to get photo and brand name?
01-21-2023, 08:01 AM | #9 |
Tink Tach
I use this. I got the recommendation from a Tom Endy article. It’s easy to install (just two wires to the coil), and it works well.
https://www.westach.com/product-page/2ct32-6v Sent from my iPhone using Tapatalk |
01-21-2023, 11:01 AM | #10 | |
Re: Tink Tach
01-21-2023, 11:25 AM | #11 |
Re: Tink Tach
What is the main advantage to adding a tachometer onto a Model A ?
Thanks, Wayne |
01-21-2023, 11:42 AM | #12 |
Re: Tink Tach
01-21-2023, 01:05 PM | #13 |
Re: Tink Tach
I read the article but I must have missed the purpose! Anyone else ? Wayne
01-21-2023, 01:27 PM | #14 |
Re: Tink Tach
01-21-2023, 01:57 PM | #15 |
Re: Tink Tach
01-21-2023, 01:59 PM | #16 |
Re: Tink Tach
01-21-2023, 02:09 PM | #17 |
Re: Tink Tach
01-21-2023, 03:42 PM | #18 |
Re: Tink Tach
Agreed. I was concerned about overreving the engine while driving, and it helps set an accurate idle speed. Also, at one point my engine was dying when coming to a stop, and a tachometer furnished a quick visual check to see if the engine was still running. (I have difficulty hearing.) Sent from my iPhone using Tapatalk |
01-21-2023, 03:45 PM | #19 |
Tink Tach
If you are an “old hand” with Model As, a tachometer is probably not needed. This was my first Model A, and the tachometer gave me a much needed comfort level learning about the engine.
01-21-2023, 05:04 PM | #20 |
Re: Tink Tach
To answer no#13, I'm curious about the engine rpm while driving at various speeds, I have Volvo O/D in the car.
Thanks guys, for all the feedback. I ordered a Tiny Tach and asked for the "little EMF filter". Post #3, gave me confidence to order one. BTW, about 2 years ago I destroyed a cheepe from Amazon in about 2 hours. herb |
