03-16-2022, 05:20 PM | #1 |
Gm t5 transmission
Is a 1989 s10 t5 a none wc ss or a wc 1352-193
03-16-2022, 06:44 PM | #2 |
Re: Gm t5 transmission
A 1989 T5 should be NWC. What are you contemplating doing? Mucho interested!! DD Your gear ratios: 1352-193 GM 1989 S-Truck 2.5L L4 Only 3.76 4.03 2.37 1.49 1.00 0.86 |
03-16-2022, 07:24 PM | #3 |
That is what I thought
03-16-2022, 08:14 PM | #4 |
WHAT are you thinking about doing with a T5, if you don't mind me asking? DD . |
03-17-2022, 01:55 PM | #5 |
I thought for a hot rod I'm working on but not strong enough for that and he wants 250.00 for it I was hoping it was a wc one but they are hard to find around here anymore
03-17-2022, 03:21 PM | #6 |
It confirms yours is not WC.
'52 F-1, EAB flathead |
03-17-2022, 03:48 PM | #7 |
Yes I found that page
03-17-2022, 06:36 PM | #8 | |
ROSS .....What did I miss? Using that British "Numbers ID" site, I'm curious how you determined that his trans is "NWC" (Non World Class)? DD |
03-17-2022, 07:27 PM | #9 |
I have sold 100's of rebuilt 85-92 S10 2 wheel drive transmissions to go behind a Flathead with no problems.
03-17-2022, 08:38 PM | #10 | |
I must agree....there is not a thing wrong with a NWC T5. In fact, I advocate using NWC "V8" Camaro T5s for the GEAR RATIOs that they use, much nicer than that 3.76 or 4.03 ist gear that comes in the S-10 boxes. IN FACT, those ridiculous 1st gear ratios are most of the reason for lower torque ratings. I was just curious how ROSS derived NWC from that British spec sheet. DD . |
03-18-2022, 09:46 AM | #11 |
It's to old to be a would class out of a s10
03-18-2022, 09:48 AM | #12 |
It's not going behind a flathead
03-18-2022, 03:11 PM | #13 |
For the S-10 rear housing AND the SHORT-SHAFT lid, that's almost a steal anymore. The "S-10" REAR housings are beginning to get scarce. Plus, they will both bolt-on to ANY T5 transmission main case. Click the link BELOW! DD https://www.ebay.com/itm/17189132278...gAAOSwHnFVy5gO . |
03-18-2022, 07:46 PM | #14 |
Coopman, the “Vehicle Application” line on the ID page has “WC” noted for world class transmissions. Any without WC in the description are thereby assumed non world class. I believe that how Ross determined it was Non-WC.
03-18-2022, 11:03 PM | #15 |
03-18-2022, 11:05 PM | #16 |
Way I see it 1993 s10 when they started the wc transmission
03-18-2022, 11:34 PM | #17 | |
Hey "BURGLAR".....Of the many hundreds of times that I have looked at that site, I can't believe that I never noticed all of those "WC" notes. Damn, I can't understand how I missed that! Thank you for setting me straight! DD . |
03-18-2022, 11:56 PM | #18 |
There was a dude on the hamb with the same handle 12 yrs ago. Same? Great name.
03-20-2022, 03:57 PM | #19 |
Tinker, I am on the H.A.M.B. as well. Same name. There may be another burglar with a slight spelling difference. Not sure. I tend to lurk more than post, so might well have been someone else. Momma always said it was better to keep your mouth shut and look stupid…….
