Old 01-21-2020, 06:20 PM   #1
Randy1944
Randy1944's Avatar
Default Crank chunk
Tore down a 1951 Ford flathead v8. When crank was cleaned and checked, this was found. Found no metal in oil pan to speak of. Certainly, nothing of this size. Any ideas?? Cast defect?? Can crank work properly with this “defect”?? 9BF491A0-D27A-47B4-92DF-6171C375C268.jpg
Randy1944 is offline   Reply With Quote
Old 01-21-2020, 06:27 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Crank chunk
Crankshafts were cast in groups, that is where it was broke off the the cluster
Old 01-21-2020, 06:27 PM   #3
JSeery
JSeery's Avatar
Looks normal to me. They were cast in groups of 4 and then broken apart, which leave the mark you are seeing.
Old 01-21-2020, 06:38 PM   #4
Randy1944
Randy1944's Avatar
Thanks for the great info. I was sure that you would have a great answer. I was concerned that it might affect the balance of the crankshaft.
Old 01-21-2020, 06:57 PM   #5
Ol' Ron
Ol' Ron's Avatar
Not a problem, but an old crank should be magged, just to eliminate a surprise.
Old 01-21-2020, 07:07 PM   #6
JSeery
JSeery's Avatar
It was balanced by Ford after that so not an issue.
