Old 04-26-2018, 05:58 PM   #1
Randy1944
Randy1944's Avatar
Default Fuel pump push rod
What length push rod should go on a Ford 8BA engine with an aluminum intake manifold? Thanks
Randy1944 is offline   Reply With Quote
Old 04-26-2018, 06:22 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Fuel pump push rod
My aluminum Offy manifold takes the same 10-1/16" long push rod as the stock cast iron manifold.
Old 04-26-2018, 06:30 PM   #3
Randy1944
Randy1944's Avatar
Thanks 51 Merc-ct, For some reason, I thought the alum.intake took a different size. Thanks
Old 04-26-2018, 08:52 PM   #4
FortyNiner
FortyNiner's Avatar
You are correct for the 59AB version.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
