Old 01-19-2023, 10:43 PM   #1
Herb Concord Ca
Default Tink Tach - Update new P/N
Hi, has anyone used the Tiny Tach tachometer? If yes, did you like it? Or any problems with the unit?
Thanks.
Tiny Tach Tech Support gave me a new p/n to order for Model A's.
1CRXL.
We'll see how this works.
Herb
Herb Concord Ca is offline   Reply With Quote
Old 01-19-2023, 10:52 PM   #2
bruceincam
bruceincam's Avatar
Default Re: Tink Tach
I've used them for years. I like them, but I use them mostly as service minders. I have them on my lawn and garden equipment. Getting kinda pricey now days. There are some less expensive Chinese subs available that seem to work well. Just search Amazon and you'll find several substitutes.
bruceincam is offline   Reply With Quote
Old 01-19-2023, 11:08 PM   #3
CWPASADENA
CWPASADENA's Avatar
I have them on 2 of my Model A's.
Like them, would highly recommend.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 01-20-2023, 06:47 AM   #4
jack wingard
how does everyone attach the wire?
jack wingard is offline   Reply With Quote
Old 01-20-2023, 07:47 AM   #5
Bruce of MN
Bruce of MN's Avatar
I bought a cheap digital tach a few years ago, but the poorly translated instruction didn't say how to set the dip switches to select 4 cylinder, etc. Is this addressed with other brands?
Old 01-20-2023, 10:36 AM   #6
bruceincam
bruceincam's Avatar
Wrap it around the plug wire a few times (three times if I recall correctly) then I use a wire tie to secure it.
Old 01-20-2023, 10:42 AM   #7
bruceincam
bruceincam's Avatar
Well, yes, the manuals can be hard to understand. But, you know what RPM range you're looking for so just experiment with the few possible switch configurations until you have an RPM in the range expected. It's not like it's going to be off 20% if you have the wrong switch settings, it's going to be off by 50% or 100% so it's pretty easy to settle on the correct settings.
Old 01-20-2023, 09:04 PM   #8
mcgarrett
Possible to get photo and brand name?
Old 01-21-2023, 08:01 AM   #9
shew01
shew01's Avatar
Default Tink Tach
I use this. I got the recommendation from a Tom Endy article. It’s easy to install (just two wires to the coil), and it works well.
https://www.westach.com/product-page/2ct32-6v
Old 01-21-2023, 11:01 AM   #10
Y-Blockhead
Y-Blockhead's Avatar
. I have an analog tach also. The tach I have has a 270° sweep and is easy to read. 12v only tho. I don't care much for a digital tach, especially in my Model A.
Old 01-21-2023, 11:25 AM   #11
McMimmcs
McMimmcs's Avatar
What is the main advantage to adding a tachometer onto a Model A ?
Thanks, Wayne
Old 01-21-2023, 11:42 AM   #12
Tom Endy
Tom Endy's Avatar
Here is the article.
https://www.santaanitaas.org/wp-cont...Tachometer.pdf
Tom Endy
Old 01-21-2023, 01:05 PM   #13
McMimmcs
McMimmcs's Avatar
I read the article but I must have missed the purpose! Anyone else ? Wayne
Old 01-21-2023, 01:27 PM   #14
alexiskai
alexiskai's Avatar
Gives you an objective rather than subjective measure of RPM.
Old 01-21-2023, 01:57 PM   #15
McMimmcs
McMimmcs's Avatar
Not to be confrontational at all but why do you need to know the RPM’s ?
Wayne
Old 01-21-2023, 01:59 PM   #16
alexiskai
alexiskai's Avatar
Wayne
Helps when you’re first learning how to shift.
Old 01-21-2023, 02:09 PM   #17
McMimmcs
McMimmcs's Avatar
Thank you very much. I appreciate your patience. Wayne
Old 01-21-2023, 03:42 PM   #18
shew01
shew01's Avatar
Agreed. I was concerned about overreving the engine while driving, and it helps set an accurate idle speed. Also, at one point my engine was dying when coming to a stop, and a tachometer furnished a quick visual check to see if the engine was still running. (I have difficulty hearing.)
Old 01-21-2023, 03:45 PM   #19
shew01
shew01's Avatar
Default Tink Tach
If you are an “old hand” with Model As, a tachometer is probably not needed. This was my first Model A, and the tachometer gave me a much needed comfort level learning about the engine.
Old 01-21-2023, 05:04 PM   #20
Herb Concord Ca
To answer no#13, I'm curious about the engine rpm while driving at various speeds, I have Volvo O/D in the car.
Thanks guys, for all the feedback. I ordered a Tiny Tach and asked for the "little EMF filter".
Post #3, gave me confidence to order one. BTW, about 2 years ago I destroyed a cheepe from Amazon in about 2 hours.
herb
