Old 09-18-2020, 07:47 AM   #1
mhsprecher
mhsprecher's Avatar
Default Starter failure
I have been helping a fellow club member get his car started. It is turning over very slowly. We replaced the starter a few months ago and he has only driven it a few times since then. It started easily as recently as last week.
During the diagnosis, I checked with a voltmeter the connection and ground per Les Andrews troubleshooting book. All checked out. I removed the starter switch and cleaned the connections, removed the fuse block from the starter to see if there was a problem with that, cleaned battery connections, cleaned the ground, ran a ground from the ground strap to the engine. Still barely turns over.
Voltage on battery was 6.2. During cranking it would reduce to 4.8 - 5 volts. Thinking it had a bad cell, we replaced the battery and no change.
My question is, could a starter have failed after only a half a dozen or so starts? Seems odd to me. The previous starter didn't last long in terms of actual use, either. Is there an electrical or operational condition that would cause repeated starter failures, or just bad luck on replacement parts?
Thanks.
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 09-18-2020, 09:45 AM   #2
katy
katy's Avatar
Default Re: Starter failure
Try switching a known good starter from another Model A and see what happens.
Old 09-18-2020, 09:50 AM   #3
mhsprecher
mhsprecher's Avatar
Katy,
Duh. That's a good idea. This is why many heads are better than one!
1924 Model T Coupe
1939 Deluxe Fordor
1945 pickup
Old 09-18-2020, 10:07 AM   #4
Will N
Will N's Avatar
Is there excessive drag in the engine? Try hand cranking it to see how easily it turns over.
Will N is offline   Reply With Quote
Old 09-18-2020, 10:25 AM   #5
mhsprecher
mhsprecher's Avatar
Will,
I will do that today. Thanks.
1924 Model T Coupe
1939 Deluxe Fordor
1945 pickup
Old 09-18-2020, 10:31 AM   #6
Purdy Swoft
Purdy Swoft's Avatar
If the starter kicks back and then acts like the battery is nearly dead , it could mean that the initial timing is too advanced or maybe forgot to retard the spark lever . If the bushings in the starter are badly worn it can cause the armature to drag on the field shoes . .
Old 09-18-2020, 01:00 PM   #7
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Connect a jumper cable between the neg batt post and the starter. Assuming you are pos ground. Try it. You may have high resistance in the neg batt cable. Easy to try.
Jacksonlll is offline   Reply With Quote
Old 09-18-2020, 01:56 PM   #8
mhsprecher
mhsprecher's Avatar
Update: tried cranking it, with plugs in. Barely turned.
1924 Model T Coupe
1939 Deluxe Fordor
1945 pickup
Old 09-21-2020, 09:59 AM   #9
Will N
Will N's Avatar
I'd also try taking the plugs out. It should turn over with very little effort with the plugs out. If you're still feeling a lot of drag, is this a very recently rebuilt engine that might not have been run in yet? If it's a broken in engine, I might start thinking about looking at the main bearings. Could be this engine was oil deprived at some point, and has begun to seize.
Old 09-21-2020, 12:30 PM   #10
Herb Concord Ca
Try#2 response or remove the starter and clean the brushes, brush holders and commutator oil the two bushing and put it back together. Test starter before installing, should spin up to 2000-3000 rpm with no load.
Herb Concord Ca is offline   Reply With Quote
Old 10-01-2020, 03:45 PM   #11
mhsprecher
mhsprecher's Avatar
We took out the plugs and put in Kroil. Went back today and on first crank it fired, but didn't stay. Still very tight. We did all sorts of things, but then let it sit for about 20 min or a half hour as we discussed other strategies. We were ready to call it a day when I suggested we try it one more time. It started right up and ran great. Let it run for a while and took it for a short spin. Came back and turned it off and it started right up again!
The carb is providing too much gas, so it needs a rebuild. After we shut it down, we removed the carb to rebuild it.
We still do not know why it is so hard to turn over? Maybe way too much gas getting into the cylinders and washing the oil off the cylinders? A bit stumped on that one. I was thrilled we got it running, though. I think there was too much gas in the cylinders and carb and it needed to dry out so it would not be flooded.
1924 Model T Coupe
1939 Deluxe Fordor
1945 pickup
Old 10-01-2020, 03:57 PM   #12
Bruce of MN
Bruce of MN's Avatar
I’m having much the same problem. I ‘ll try all these steps.
Bruce of MN is offline   Reply With Quote
Old 10-01-2020, 04:02 PM   #13
mhsprecher
mhsprecher's Avatar
Gee, Bruce. I was telling Tom Terko today about how much you have been driving your car lately!
We were very frustrated and then the darned thing started right up. Hard to figure out.
1924 Model T Coupe
1939 Deluxe Fordor
1945 pickup
Old 10-01-2020, 04:42 PM   #14
Fred K OR
I was thinking it could be a bad battery. Just a guess.
Fred K OR is offline   Reply With Quote
Old 10-01-2020, 06:57 PM   #15
mhsprecher
mhsprecher's Avatar
Replaced a good battery with a new battery, but that wasn't the problem. Still cranking slowly. Oh, well. It starts well - for now. We will put the rebuilt carb on and see what happens.
1924 Model T Coupe
1939 Deluxe Fordor
1945 pickup
Old 10-01-2020, 08:15 PM   #16
McMimmcs
McMimmcs's Avatar
Good call Fred! Lucky they had you around!
McMimmcs is offline   Reply With Quote
Old 10-02-2020, 03:59 PM   #17
Bruce of MN
A new battery did it for me.
Old 10-04-2020, 09:05 AM   #18
30 Closed Cab PU
With the ignition and fuel off, measure voltage across different places when cranking the motor to see if there are bad connections causing a voltage drop. Across connections/cables/etc. Perhaps a cable, or mechanical connection needs attention. If not aware, many add an additional cable from the battery ground at the frame to the bell housing to provide a better ground path for the starter.
30 Closed Cab PU is offline   Reply With Quote
Old 10-04-2020, 10:33 AM   #19
Purdy Swoft
Try the starter with the ignition switch off . If the starter turns normal with the switch off but drags with tthe ignition on , the timing is too advanced . Also check points gap . If points gap is over twenty two thousands it will cause the timing to be too advanced .
