Old 09-16-2020, 10:14 AM   #1
MatiasMyles
Default Brake Cross Shaft Diameter?
I'm going to replace the service brake cross shaft bushings on my '31. I was wondering what the diameter of the shaft, where the bushing go, should be to safely use the standard 2 piece bronze bushing. I would want to order a repair kit the same time that I order the bushings if needed. Thank youappvalley tutuapp tweakbox
MatiasMyles is offline   Reply With Quote
Old 09-16-2020, 10:38 AM   #2
katy
katy's Avatar
Default Re: Brake Cross Shaft Diameter?
I just measured one, it was 13/16" (.8125")
Old 09-16-2020, 11:57 AM   #3
lrjones
I just did mine last week and both ends measured .079. Do a search on my post as it received several good replies. The 2 piece fit just fine with minor filing.
lrjones is offline   Reply With Quote
Old 09-16-2020, 12:24 PM   #4
wwirz
Be careful of decimals. 13/16 is .8125. The above .079 is likely .79 inches or 25/32.
wwirz is offline   Reply With Quote
Old 09-16-2020, 01:37 PM   #5
lrjones
I stand corrected, mine was .79. Long day
Old 09-16-2020, 02:46 PM   #6
katy
katy's Avatar
When I typed it in I thought it didn't look right.
